HELP! TIMING BELT. CAR WONT START
Old Aug 14, 2006 | 07:11 PM
DaKINE-Ek's Avatar
From: So Cal where old pople try to race you, U.S.A
Default HELP! TIMING BELT. CAR WONT START
ok so i attempted to do my timing belt and failed so i put back everything together and then tried to start it and now it wont start. it turns and the car shakes A LOT but doesnt turn on fully.
Old Aug 14, 2006 | 07:28 PM
Luserkid's Avatar
Default Re: HELP! TIMING BELT. CAR WONT START (DaKINE-Ek)
Redo the belt again until you get it right. Sadly thats all you could do. Also to help you out is do a compression check each time you finish to know if its good.
Old Aug 14, 2006 | 07:58 PM
DaKINE-Ek's Avatar
Default Re: HELP! TIMING BELT. CAR WONT START (Luserkid)
but i didnt get the belt on to begin with. i tried to get it off and i just quit and put everything back together and now it wont start.
Old Aug 14, 2006 | 09:01 PM
DaKINE-Ek's Avatar
Old Aug 14, 2006 | 11:24 PM
Luserkid's Avatar
Retrace your steps with us, what did you do? You sure everythings hooked up correctly?
Old Aug 15, 2006 | 12:46 AM
L33TsAbabyEater's Avatar
DaKINE-Ek
Access Level Normal User
Permission Level iServe User
Age 19
<U>User Statistics</U>
1300 posts (1.44 posts per day on average)
DaKINE-Ek last posted at 10:18 PM 8/14/2006
DaKINE-Ek has been a member for 900 days.
1300 Posts and you still cant do your own timing belt?
Old Aug 15, 2006 | 05:51 AM
miahmouse's Avatar
Assuming that you didn't move the timing belt at all...
check your plug wires, you've probably gotten them swapped...
Old Aug 15, 2006 | 05:58 AM
miahmouse's Avatar
Default Re: HELP! TIMING BELT. CAR WONT START (SalmonMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SalmonMan &raquo;</TD></TR><TR><TD CLASS="quote">
1300 Posts and you still cant do your own timing belt? </TD></TR></TABLE>
I see your point, but rather than criticizing, why not offer technical advice... this is a tech forum after all...
Old Aug 15, 2006 | 06:57 AM
TorquelessB16's Avatar
You can't just tell us you "failed" and expect any specific help. How far in the process did you get? What were you stuck on?
Old Aug 15, 2006 | 08:44 AM
DaKINE-Ek's Avatar
Default Re: HELP! TIMING BELT. CAR WONT START (ZeeSix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SalmonMan &raquo;</TD></TR><TR><TD CLASS="quote">DaKINE-Ek
Age 19
first of all i dont see how having a high post count will enable me to do a timing belt, but as far as what i did. i got as far as removing the a/c belt and alternator belt and when it came to taking the crank pulley bolt off i couldnt. so i just gave up and put everything back the way i found it and now when i try and crank the car it turns over but it doesnt start because it sounds like something is stuck and the car just dies.
Old Aug 15, 2006 | 10:27 AM
WONG FRIED RICE's Avatar
what exactly did you do or NOT do? what did you remove or change?
your timing might have changed...
spark plug wires not in correct order, not plugged in all the way? etc. etc.
there's lots of things that could be wrong... we just need to know exactly what you did.
Old Aug 15, 2006 | 10:33 AM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaKINE-Ek &raquo;</TD></TR><TR><TD CLASS="quote">first of all i dont see how having a high post count will enable me to do a timing belt, but as far as what i did. i got as far as removing the a/c belt and alternator belt and when it came to taking the crank pulley bolt off i couldnt. so i just gave up and put everything back the way i found it and now when i try and crank the car it turns over but it doesnt start because it sounds like something is stuck and the car just dies. </TD></TR></TABLE>
Did you remove the spark plug wires or the distributor in this process? It's pretty difficult to help you when you're only giving us the tiniest bit of information relevant to the situation.
Old Aug 15, 2006 | 10:56 AM
oscarmayer's Avatar
did you plug the crank angle sensor plug back in?
Old Aug 15, 2006 | 10:57 AM
DaKINE-Ek's Avatar
Default Re: HELP! TIMING BELT. CAR WONT START (Archidictus)
i only removed the spark plug wires. not from the distributor but from the valve cover so i can get it off, removed the upper timing belt cover, then proceded to remove the a/c belt, then the alternator belt, then i proceded to try and remove the crank pulley bolt with a impact gun, it wouldnt come off so i put everything back the way it was and tried to crank it and wont start now. could i have thrown off the timing or anything like that by what i did? i also removed my spark plugs and checked them and the tips looked to be caked with carbon and the #4 spark plug had gass on it. when i try and crank the car it sounds like it wants to turn over but there is something holding it back like its stuck or something.
patm95
Honda Civic (2001 - 2005)
Oct 4, 2013 06:29 AM
[713]
May 14, 2012 03:23 PM
green_si
18
Mar 3, 2010 03:24 PM
VanHonda
Dec 7, 2006 05:38 PM
tangb2023
Jul 9, 2003 09:17 PM
