What DO i Need?????
Old Aug 14, 2006 | 06:43 PM
Nicaraguense13's Avatar
Default What DO i Need?????
I have a 98 honda civic DX hatchback Doing a LS swap i have these questions
1. Which Mounts would i need to buy?(stock or aftermarket which ones? give me responese to both options please)
2. Axles- which Yr axles do i have to buy from A 98 ls integra??
3. ECu- which ecu?
4. Also If anyone knows if anyone has a Link to a Step by step or DIY on Engine obd2 Civc Harness Conversion to Fit a LS??
sorry for so many question have to make sure before jumping in
Old Aug 14, 2006 | 07:15 PM
ci_v_ic's Avatar
Default Re: What DO i Need????? (Nicaraguense13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nicaraguense13 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 98 honda civic DX hatchback Doing a LS swap i have these questions
3. ECu- which ecu?
sorry for so many question have to make sure before jumping in </TD></TR></TABLE>
1. you can get mounts from hasport. dont really know if stock mounts would work.
2. axles somebody else can help you out with that lol
3. if your going lsvtec you can use a p72
Old Aug 14, 2006 | 07:47 PM
Sleepy_Red_hatch's Avatar
Default Re: What DO i Need????? (ci_v_ic)
1 - i believe the LS tranny upper mount, and the rest is off a 99-00 SI(i THINK, i'm an EG guy), as for the aftermarket, get hasport B-series into EK mounts
2 - ANY B-series axles will do.
3 - use the ECU that corresponds to the motor and the OBD compliance you want to run,
4 - sorry, cant help you there
Old Aug 15, 2006 | 06:18 PM
ci_v_ic's Avatar
Default Re: What DO i Need????? (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">3 - use the ECU that corresponds to the motor and the OBD compliance you want to run,</TD></TR></TABLE>
x2, i thought since it was a 98 you would at least spring for the obd-2 setup but hey you never know.
PoonAndSpoon
Jul 6, 2011 07:09 PM
hotcivicsi
Oct 15, 2009 03:04 PM
firehouse
Jul 20, 2006 09:07 PM
AJxr
Feb 24, 2006 12:28 AM
mycvc8u2
Jan 5, 2003 12:18 AM
