Where did you get your thin H22 head gasket from?
Old Aug 14, 2006 | 06:19 AM
sivikvtec's Avatar
Default Where did you get your thin H22 head gasket from?
I'm trying to get my compression up without messing with my block. I don't want to mill the head either. I can find thicker ones for boost applications, but who sells a quality thin one? Any help is greatly appreciated.
Old Aug 14, 2006 | 05:54 PM
sivikvtec's Avatar
Default Re: Where did you get your thin H22 head gasket from? (sivikvtec)
nobody here has a thin head gasket?
Old Aug 14, 2006 | 05:59 PM
MadCityLude
Guest
Posts: n/a
pull middle layer from the stock one
Modified by MadCityLude at 1:08 PM 8/15/2006
Old Aug 14, 2006 | 06:52 PM
petern101's Avatar
Default Re: Where did you get your thin H22 head gasket from? (MadCityLude)
spoon sells a thin headgasket. you finding one might be an issue though.
and for what its worth, there are other ways to make power.
Old Aug 14, 2006 | 07:33 PM
Eddiebx's Avatar
take a stock one and pull out the middle layer.
Old Aug 14, 2006 | 09:18 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">take a stock one and pull out the middle layer.</TD></TR></TABLE>
X2.. also use plenty of copper spray.
Old Aug 15, 2006 | 12:52 AM
snowblind7x's Avatar
Default Re: (cb7-R)
there isn't ANY company that has a thin head gasket for a H22 readily available?
Old Aug 15, 2006 | 08:36 AM
Eddiebx's Avatar
Default Re: (snowblind7x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowblind7x &raquo;</TD></TR><TR><TD CLASS="quote">there isn't ANY company that has a thin head gasket for a H22 readily available?</TD></TR></TABLE>
its the same thing, a mugen or spoon thin gasket is 2laysers, like an oem with the mideel removed is 2layers.
Old Aug 15, 2006 | 09:25 AM
soundbomber's Avatar
cometic?
Old Aug 15, 2006 | 10:05 AM
prelittlelude's Avatar
X3
just remove the middle layer.. likely this is what other companies do that sell 2 layers,
Old Aug 15, 2006 | 10:45 AM
Finest's Avatar
Default Re: (prelittlelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">
just remove the middle layer.. likely this is what other companies do that sell 2 layers, </TD></TR></TABLE>
But put it in some cool packaging, slap on their logo and charge 3x the price!
Old Aug 15, 2006 | 11:50 AM
It's ok just to take out the middle layer and then just put it back together?
Old Aug 15, 2006 | 12:01 PM
l2yanE's Avatar
http://www.raceeng.com sells them check there-
Old Aug 15, 2006 | 12:49 PM
sivikvtec's Avatar
Default Re: (l2yanE)
so who here is actually driving with 1 layer removed? Is there any way to find out how much compression you can gain from this? Is 0.5 too optimistic?
Old Aug 15, 2006 | 12:50 PM
Eddiebx's Avatar
It's ok just to take out the middle layer and then just put it back together?</TD></TR></TABLE>
yes just bend the copper rivets this will let the HG fall apart. then remove the middle layer and install. dont worry about the rivets, they are only there to hold the gasket together while handling. the gasket will be centered when u intsall the alignment dowels in the head.
Old Aug 15, 2006 | 01:00 PM
Missing Gears's Avatar
use only one of the outer layers of the stock gasket, ive been doing it for years and works great. do not use copper spray.
btw, spoon thin gasket is exactly what i mentioned above.
Old Aug 15, 2006 | 01:29 PM
sivikvtec's Avatar
Default Re: (Missing Gears)
What is the copper spray supposed to do? There's no sealing issues with only running one outer layer? Am I risking anything by doing so? Thanks for the help.
Old Aug 15, 2006 | 01:34 PM
madcatz's Avatar
wait....one guy says use copper spray, while you say dont?
which one is it? Im about to do a head build and will be doing the OEM headgasket, but do I or dont I use the copper spray?
Old Aug 15, 2006 | 01:49 PM
Eddiebx's Avatar
Default Re: (madcatz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madcatz &raquo;</TD></TR><TR><TD CLASS="quote">wait....one guy says use copper spray, while you say dont?
which one is it? Im about to do a head build and will be doing the OEM headgasket, but do I or dont I use the copper spray?</TD></TR></TABLE>
if you really want to use copper spray just use some between the two outer layers. theres definitely no need for coper spray on the block and head mating surfaces as u are still using the outer layers of the head gasket.
Old Aug 15, 2006 | 02:09 PM
sivikvtec's Avatar
What does copper spray do? Resist corrosion from the different metals touching? Or does it seal the head to the block?
Old Aug 15, 2006 | 05:21 PM
Eddiebx's Avatar
suppose to make a better seal i believe.
Old Aug 15, 2006 | 05:23 PM
http://www.cometic.com/sportcompact.aspx
Old Aug 16, 2006 | 05:10 PM
Default Re: (soundbomber)
if you need copper spray to make your headgasket seal better, your doing something wrong. do not use it w/ the factory or cometic gaskets.
96lude_srv
Jul 13, 2011 06:01 AM
evilone
Dec 22, 2004 02:37 AM
skunkd lude
Feb 22, 2004 05:59 PM
buck02
Jun 2, 2003 04:47 AM
EgSick
Dec 21, 2002 12:32 PM
