copper head gasket help please
Old May 31, 2003 | 04:21 PM
buck02's Avatar
Default copper head gasket help please
i have a h22 with a oring head witha stock thickness of the gasket but man i hear they leak really bad but i put spray lots of copper spray on the gasket and let it get takky do you think it will hold it has arp head bolts and torqued too 110ftlbs i hope it wont leak any one has had this could you tell mee if it will leak
Old May 31, 2003 | 04:26 PM
ladysman's Avatar
Default Re: copper head gasket help please (h22civic2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22civic2 &raquo;</TD></TR><TR><TD CLASS="quote">i have a h22 with a oring head witha stock thickness of the gasket but man i hear they leak really bad but i put spray lots of copper spray on the gasket and let it get takky do you think it will hold it has arp head bolts and torqued too 110ftlbs i hope it wont leak any one has had this could you tell mee if it will leak </TD></TR></TABLE>
I can't tell you if it will leak but 110 ft lbs on the head bolt torque is too much. 70 is about right. You could warp the head torquing it that much.
Old May 31, 2003 | 07:03 PM
speedworks's Avatar
Default Re: copper head gasket help please (ladysman)
apply a super thin coat of hondabond or permatex ultra grey around every passage on the head and block that coolant goes through. use two coats of copper seal on both sides of the head gasket. torque to 76 foot pounds. works great for me.
Old May 31, 2003 | 07:05 PM
buck02's Avatar
Default Re: copper head gasket help please (speedworks)
well im using a 350 head bolt the block was retapped there was no head studs for the h22 at the time so i didnt go no more than that do you think it will be fine its oringed and i sprayed both sides with copper coat if it leaks i think i was going to use the factory head gasket or the stell but man i dont want it to leak i hope it should hold
Old May 31, 2003 | 07:11 PM
speedworks's Avatar
i'm not sure if will leak or not. i was told by an old school racer to put some type of gasket maker around the coolant before installing the head to reduce leaking coolant when using a copper head gasket. i have done this from day one and have had no problem so far.
Old May 31, 2003 | 07:18 PM
buck02's Avatar
so before i get it tuned do you guys think i should take that copper gasket off and use a diffrent one because i rather do it now before i send it to get tuned what would you recomend any help i need to know soon because the day is coming for dr. bob norwood to tune the motec and i need it right and not have any problems what you guys recomend for a oringed head please healp all the turbo guys that are engine builders tony art etc etc.....
Old May 31, 2003 | 08:27 PM
MotorMatrix.com's Avatar
I am a bad person
110ft lbs of tq on the head is way over tq'd. with arp studs it should be 80-85ftlbs.so you are using a stock headgasket with just copper spray right?? what kind of o-ring are you using, copper, stainless?? you say the head is ringed. is there a receiver groove in the head or is the block o-ringed??
Old May 31, 2003 | 08:32 PM
buck02's Avatar
Default Re: copper head gasket help please (MotorMatrix.com)
motormatrix man im sorry i forgot ask you **** i wasnt thiking im sorry any ways look i have a copper head gasket with copper spray on both sides 2 coats on both sides on the oring i ringed just the head not the block no recieving groove in the block what is a good head gasket im ready to finish this head gasket **** once and forall before bob norwood tunes it its never been started on this fresh block please help anyone
Old May 31, 2003 | 08:42 PM
I am a bad person
I have no experience with the o-ring in the head to be honest. our h22 race car has no o-ring at all and never popped a gasket at 26psi and 689whp. My opinion is run a stock gasket and use copper spray and 85lbs of tq on the studs. thats what works for me. make sure the 0-rings are copper not stainless. if they are stainless you may have to run the copper gasket. I had pretty bad luck with stainless o-rings. my next block will not run o-rings. they are more headache then good I think.
Old May 31, 2003 | 08:54 PM
buck02's Avatar
so i need to find out if there stainlees or copper rings if so stainless should i back off the the bolts and retourqe them to like 85ftlbs or just leave it and if there copper im deffinatly taking out and putting a stock headgasket in thanks motormatrix
Old Jun 1, 2003 | 05:43 AM
buck02's Avatar
bump tony or art can you thow mw some info please
Old Jun 1, 2003 | 07:17 PM
buck02's Avatar
bump toney or art please help need some info before i bring to you
Old Jun 1, 2003 | 10:15 PM
tony1's Avatar
Hey buck, i'm pretty sure you've got 1/2" studs, so you're ok on the torque. I use copper orings and stock headgaskets. If you do use a copper gasket then you HAVE to use steel orings, but i've never had good luck with that setup. The stock gaskets are proven...
Old Jun 2, 2003 | 04:47 AM
buck02's Avatar
Default Re: copper head gasket help please (tony1)
tony i will have to call and ask bob wht oring i have because man i hate for it to leak when you get it i had prob with them before so i if have steel oring can i use a stock with it too or know i can only use a copper with the steel because i need to change it what tourqe do i need to go if i use a stock gasket
ghozt107
Apr 2, 2010 08:22 PM
Specail Ed
Nov 20, 2009 07:09 AM
Natural Aspirations
18
Dec 19, 2007 02:21 PM
Lewcis
Jun 24, 2004 11:02 PM
DLB1994
Feb 23, 2002 10:17 PM
