help broken header bolt stuck on head
Old Aug 13, 2006 | 04:52 PM
dademax24's Avatar
Default help broken header bolt stuck on head
hey well i have a sohc and i broke half of the head bolt that goes to the header inside the head i need help how to get it out or what do i have to do ?? thanx
Old Aug 13, 2006 | 04:55 PM
slammedEM1Si's Avatar
i think sears sells stud removers, its like a drill bit
or you can take it to a machine shop.
but dang, how did u manage to break em?
Old Aug 13, 2006 | 05:35 PM
Syndacate's Avatar
Drill out the inside until the structural stability on the outside crumbles.
Old Aug 13, 2006 | 07:35 PM
tempsohc's Avatar
drill a little hole in the center then grab a extractor kit...pound the proper size extractor into the hole you previously drilled and thehn use a open end or crescent on the extractor...then retap the threads or helicoil dat shiet...good luck
Old Aug 13, 2006 | 07:42 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: (slammedEM1Si)
exactly, what the hell did u do? cross thread it. do what the last guy said, but try the stud remover from craftsman first.
i would
1. try stud removing tool
2.Try vise grips
3.drill hole through center of stud and drill hole........if u get to this point, use a center punch first, then drill with a small drill bit and work your way up.
If you drill the hole stud out, u run a chance of fu@king the threads up in the head.
akademikz26
Aug 23, 2006 04:28 PM
JerseySiPOS
Welding / Fabrication
25
Mar 24, 2006 04:38 AM
the.hamburglar
Jul 23, 2005 09:44 PM
gsrmike
Apr 11, 2004 12:06 PM
JBBNJ609
Jan 4, 2004 08:57 AM
