bad TPS and IACV
Old Aug 13, 2006 | 10:26 AM
SP GARAGE's Avatar
Default bad TPS and IACV
i recently just put a poormans into a gsr shell and it has a type-R manifold and TB. but when i started it up after about 4 mins the car would start surging like a vacuum leak. i know its not the TB because we put it on my buddies car and it worked fine. and i know its not the IACV becauase we tried it on my friends car. could it be a ECU problem?? i was running a p72 ECU. please help me out
Old Aug 13, 2006 | 10:39 AM
DC2 Mang's Avatar
Default Re: bad TPS and IACV (mixxxwell)
any CEL's?
sounds like a vacuum leak, possibly a cracked intake manifold gasket or IACV gasket
Old Aug 13, 2006 | 11:10 AM
SmogKing's Avatar
Default Re: bad TPS and IACV (DC2 Mang)
Check if you have any codes. If you had a disconnected or broken vacuum lines your car would'nt be surging, a big vacuum leak would make your car idle higher.
Old Aug 13, 2006 | 11:21 AM
SP GARAGE's Avatar
i checked the CEL's and it said TPS and IACV. if it was a vacuum leak wouldnt it start surging right away?? it doesnt start surging until its warm
Old Aug 13, 2006 | 11:25 AM
DC2 Mang's Avatar
clean out your IACV, and FITV that is located on the throttle body
Old Aug 13, 2006 | 11:47 AM
SP GARAGE's Avatar
i just cleaned out the IACV imma try cleaning the FITV
Old Aug 13, 2006 | 03:42 PM
VTECth1s's Avatar
Default Re: (mixxxwell)
goodluck cleaning the FITV..its a b*tch trying to get to it..i had enough stress getting the IACV by myself and having big arms you can barely fit your arms anywhere in the engine bay
HIallday
Sep 13, 2011 10:34 PM
Excusetoboost
Sep 1, 2011 07:40 PM
SOHC_civic_si
16
Dec 29, 2010 02:25 PM
rtiadnoh
Feb 15, 2004 12:41 PM
Vp Special K
26
Nov 9, 2003 10:24 AM
