How hard is it to pry off axles.
Old Aug 13, 2006 | 08:51 AM
PrinceAli132's Avatar
Default How hard is it to pry off axles.
Having a real hard time removing the axles, i'm even try to pry off the passanger side and can't seem to get it to budge at all.
Ali
Old Aug 13, 2006 | 08:57 AM
Reid's Avatar
Global Moderator
Default Re: How hard is it to pry off axles. (PrinceAli132)
Are you trying to remove the axle from the transmission or from the hub?
Old Aug 13, 2006 | 08:58 AM
Default Re: How hard is it to pry off axles. (Reid)
tranny
I was going to leave them in the hub and just support them so they can hang while i drop the tranny to replace the clutch, flywheel and pressure plate.
Ali
Old Aug 13, 2006 | 08:59 AM
typer_696's Avatar
Hey Ali you know you got Type R friends down here. You can call and it can be down. That is a 2 hour job in and out.
Old Aug 13, 2006 | 09:00 AM
Default Re: How hard is it to pry off axles. (typer_696)
I literally called you 10 mintues ago. But i think i spoke to you dad.
I would really appreciate if you can come over and help out. Stop by if you can ill be home all day.
Ali
Old Aug 13, 2006 | 09:01 AM
To bad i spend about 4 and stil haven't removed the tranny.
Ali
Old Aug 13, 2006 | 09:13 AM
Reid's Avatar
Global Moderator
I pry axles out of the tranny with two flat head screwdrivers, prying on opposite sides of the mating surface. The axle will eventually pop right out with this method. The axle can be tapped out of the hub with a rubber hammer, if it won't slide right out on its own.
Good luck.
Old Aug 13, 2006 | 09:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">I pry axles out of the tranny with two flat head screwdrivers, prying on opposite sides of the mating surface. The axle will eventually pop right out with this method. The axle can be tapped out of the hub with a rubber hammer, if it won't slide right out on its own.
Good luck. </TD></TR></TABLE>
Thanks, ill give that a try. The only thing is with the hub side where the nut is indented in, im having a hard time getting it to punch out. I try to use a thin flathead but i am afraid of messing up the axle.
Thanks again.
Ali
Old Aug 13, 2006 | 09:35 AM
ng15ek9's Avatar
yea man, I use a 12" prybar, stick it in the where the axle meets the trans and give it a good wack with the palm of your hand.
&lt; walker111
Old Aug 13, 2006 | 09:58 AM
Dave_B's Avatar
Default Re: How hard is it to pry off axles. (ng15ek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ng15ek9 &raquo;</TD></TR><TR><TD CLASS="quote">yea man, I use a 12" prybar, stick it in the where the axle meets the trans and give it a good wack with the palm of your hand.
&lt; walker111</TD></TR></TABLE>
Walker111? Jim, WTH?
Ali, just bring that bish up here. We can pull them out for ya.
Just for curiosity sake, why you pulling the trans? Time for clutch?
Old Aug 13, 2006 | 10:09 AM
Default Re: How hard is it to pry off axles. (Dave_B)
Yea, replacing the clutch, pressure plate, flywheel, and rear mount.
Ill probably be paying you a visit for the T-Belt.
Ali
Old Aug 13, 2006 | 10:10 AM
Oh yea, i did get the passanger side out. Time to work on the driver side
Ali
Old Aug 13, 2006 | 10:26 AM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">Yea, replacing the clutch, pressure plate, flywheel, and rear mount.
Ali</TD></TR></TABLE>
Just LMK when your coming. I'll make some time for ya.
Old Aug 13, 2006 | 10:45 AM
LUCKY CHARMS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">
Just LMK when your coming. I'll make some time for ya.</TD></TR></TABLE>
i wish it was that easy on this side of the atlantic
Old Aug 13, 2006 | 05:28 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">Oh yea, i did get the passanger side out. Time to work on the driver side
I'm lazy, so I often just unbolt the intermediate shaft with the driver's side axle still connected to it.
Old Aug 13, 2006 | 05:40 PM
Thats what i did, and it the intermediate shaft came right out. Was just about to take off the tranny, had to remove the two motor mounts and ended up braking two rachtes leaving me with nothing. And i could even go back to Sears to replace them cause they already closed. So i have to wait till tomorrow.
To not having a full set of tools
Thanks again Reid and everyone else for helping me out. Hopefully everything else will go pretty smoothly.
Ali
Old Aug 13, 2006 | 08:41 PM
Black R's Avatar
25 Year Member
i was going to post some help, but it looks like you're almost done.
Old Aug 14, 2006 | 07:05 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (Black R)
Dis was me on a friends computer.
DS axle I just beat on with a hammer till it seperates from the half shaft....
cfoamcvc
Feb 15, 2007 07:17 AM
95lstegman
Apr 12, 2005 02:38 PM
Rob :190:
Feb 22, 2003 08:44 AM
94CivicSi
Feb 26, 2002 11:17 AM
Lei Siew Long
Aug 14, 2001 11:55 AM
