B18c head: exhaust side valve springs
Old Aug 12, 2006 | 08:28 PM
chu77's Avatar
Default B18c head: exhaust side valve springs
I'm resitting the valves on my b18c head and also replacing two intake valves. The intake side has two valve springs, One outer and one inner. However on the exhaust side there are only one outter spring. Are there suppose to be two on the exhaust as well? The manual says nothing about that.
Old Aug 12, 2006 | 10:24 PM
qfast817's Avatar
Default Re: B18c head: exhaust side valve springs (chu77)
nope thats the way it is on my obd1 head
Old Aug 13, 2006 | 07:33 AM
Dogginator's Avatar
Daisy... Daisy...
Yes, the P72 heads came stock with double intake and single exhaust springs. Why don't you buy some ITR intake springs and move the GSR intake springs to the exhaust side? ITR exhaust spring = GSR intake springs.
Old Aug 13, 2006 | 05:57 PM
chu77's Avatar
Default Re: B18c head: exhaust side valve springs (Dogginator)
Takes too long to take out all the springs againlol
Also, are b16 intake valves interchangable with the b18c valves?
Old Aug 13, 2006 | 06:11 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chu77 &raquo;</TD></TR><TR><TD CLASS="quote">Takes too long to take out all the springs againlol</TD></TR></TABLE>
It's easy with the head off of the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chu77 &raquo;</TD></TR><TR><TD CLASS="quote">Also, are b16 intake valves interchangable with the b18c valves?</TD></TR></TABLE>
Yes. You can always check the part numbers with the links in my signature. This would be a great time to install ITR intake valves.
Bama Built
May 16, 2018 07:33 AM
servion
Apr 8, 2003 12:14 AM
McFly
Feb 12, 2003 08:27 PM
OBDI JEDI
Jan 28, 2003 10:47 AM
