Tech Help>>>>>>>>>>>>
Old Jan 28, 2003 | 10:16 AM
OBDI JEDI's Avatar
Default Tech Help>>>>>>>>>>>>
Would milling a B18C1 head .20 and using a Mugen Head gasket with my 10.8:1 pistons raise the CR to around 11:1?
Also when putting the ITR valve springs in my cylinder head, i take the GSR inner springs move them to the exhaust side, and place the ITR intake valve springs on the intake side correct? or should i just run the ITR exhaust valve springs on the exhaust side?
Thanxs for your guys help in advance!
_______
Old Jan 28, 2003 | 10:36 AM
au-gsr's Avatar
Default Re: Tech Help>>>>>>>>>>>> (OBDI JEDI)
i think you have that backwards- the exhaust springs ar ethe same as the r's. also the retainers you have in the car are also the same as the r's. so all you have to do is buy a set of intake springs
Old Jan 28, 2003 | 10:47 AM
OBDI JEDI's Avatar
Default Re: Tech Help>>>>>>>>>>>> (au-gsr)
ermmmm i have both already lol so just swap out the intake side?
Bama Built
May 16, 2018 07:33 AM
92db2gs-r
Feb 27, 2011 03:54 PM
Jintegragsr97
Feb 21, 2008 08:44 PM
Convoy
Dec 29, 2003 09:48 PM
OBDI JEDI
Jan 29, 2003 07:55 AM
