Which torque wrench to buy?
Old Aug 11, 2006 | 07:40 PM
Simple SOHC's Avatar
Default Which torque wrench to buy?
Alright...I'm lookin to get a torque wrench to do my headgasket, but also to have around whenever I need it. I'm planin on buying one from Craftsman...here are the 3 I'm lookin at:
1/2in drive 20-150 ft/lbs
3/8in drive 10-75 ft/lbs
3/8in drive 25-250 ft/lbs
I'm lookin to get one that I will use the most. I'm guessin either the 1/2in drive or the 3/8in drive 10-75 ft/lbs. Anyone have any pointers?
Old Aug 11, 2006 | 07:43 PM
Paxil4x4's Avatar
Default Re: Which torque wrench to buy? (Simple SOHC)
Get the 3/8 because unless you have a bunch of 1/2 sockets when you stick adapter and stuff on a 1/2 the accuracy can change a little bit.
Old Aug 11, 2006 | 07:49 PM
fmrprojects's Avatar
Default Re: Which torque wrench to buy? (packthis)
i have 2. 3/8 5-75 and 1/2 20-150
Old Aug 12, 2006 | 02:10 AM
92ehatch's Avatar
Default Re: Which torque wrench to buy? (fmrprojects)
get all of them.
then you always have the right one
Old Aug 12, 2006 | 09:17 AM
Deckard's Avatar
I would say 1/2 inch, or wait until Sears has a sale and get both 3/8 & 1/2. One bad thing about the new Craftsman torque wrenches is they have plastic handles and dials. My freind got one and the damn plastic broke the first day!
Old Aug 12, 2006 | 09:19 AM
Sean @ ESG's Avatar
I have a 1/2" drive. The 3/8's would be nice for torquing suspension and motor parts though
Old Aug 12, 2006 | 10:26 AM
florida's Avatar
I'm very happy w/ my 3/8 inch wrench from Crapsman. It's like 5-80lbs (our lugs should be at 75-80 I believe). I just put new suspension on and it worked great.
Make sure that whichever wrench you get it goes low enough to reach the lowest torque values your gasket will require. i don't know anything about doing that, but doesn't it go something like 5lbs first on all bolts, then 10lbs, then the final number???
Old Aug 12, 2006 | 12:55 PM
HeikDiesel's Avatar
Default Re: (florida)
Im not sure the spec of head bolts or nuts if using aftermarket but torque wrenches are a little less accurate at the very edges of the spec....so I know probably 80lb ft is too much but if thats what that wrench does I get something more like 50-150 for that task. Have it calibrated when needed....also remember that the twist type need to be zeroed out every time but dial types like my snap on do not have to be zeroed out to keep from stretching the spring
Old Aug 12, 2006 | 01:12 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Simple SOHC &raquo;</TD></TR><TR><TD CLASS="quote">Alright...I'm lookin to get a torque wrench to do my headgasket, but also to have around whenever I need it. I'm planin on buying one from Craftsman...here are the 3 I'm lookin at:
I'm lookin to get one that I will use the most. I'm guessin either the 1/2in drive or the 3/8in drive 10-75 ft/lbs. Anyone have any pointers?</TD></TR></TABLE>
you can do what i did. i have the 1/2 torque wrench (ft/lbs.) and the 3/8 (in/lbs.)
bith are craftsman by the way.
Old Aug 12, 2006 | 01:27 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: Which torque wrench to buy? (philosofy1)
is there a digtal torque, i heard about em
philosofy1's Avatar
Default Re: Which torque wrench to buy? (BLUE EH3)
yes there is, but i don't think craftsman makes one.
Old Aug 12, 2006 | 02:13 PM
BLUE EH3's Avatar
Help we my pennies
its 1200$
Old Aug 12, 2006 | 04:56 PM
bsixteen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">is there a digtal torque, i heard about em</TD></TR></TABLE>
yep, my cousin has 3 digital ones. i don't think from craftsman though. it vibrates and as an audio alarm when you've reached the torque limit you set it to.
Old Aug 12, 2006 | 06:38 PM
suspendedHatch's Avatar
Default Re: Which torque wrench to buy? (bsixteen)
I have both the 3/8in drive 10-75 ft/lbs and the 3/8in drive 25-250 ft/lbs. Anything that requires a half inch drive is usually too high of a spec to use a torque wrench on. I torque **** like that (axle nuts, crank pulley etc) using the air gun.
Old Aug 13, 2006 | 06:58 PM
KayOs's Avatar
Snap-On tools has one and its not $1200.
Old Aug 13, 2006 | 07:12 PM
95DxSi-R2
Guest
Posts: n/a
by the way the 3/8 25-250 is inch lbs., just get the 1/2 inch 20-150. i have all the craftsman tq. wrenches. they are very dependable, your probably gonna start out at 20,45, then the final. have fun
wc4ohio
Apr 21, 2011 10:58 AM
1SlowSi
Dec 20, 2004 01:43 AM
Tropicana18T
Mar 6, 2004 09:18 AM
Hayasa15
May 27, 2003 05:29 AM
madtownhonda
Mar 17, 2003 07:43 AM
