What can I expect to run with this setup? and how much boost?
I have a 93 del sol si, d16z6, with a greddy turbo TD04 kit, fmic, 2.5 inch piping, high flow cat, buddy club muffler, a.c.t. clutch and flywheel, high horsepower axles, I wanted to know how much boost I can run safely at the most at the track with my stock internals and what I should expect to run in the 1/4 mile? I haven't been to the track yet and just wanted to know what to expect. Thanks.
How much boost are you running right now?
tuned? what program?
On a stock SOHC is 8psi...
about 145hp on a del sol 14 second car
The kit came with everything you needed for a basic turbo setup, it also came with greddy e-manage, I'm running stock injectors with 6 pounds of boost daily. I didnt no how much I can turn the boost up to with the z6, I have a manual boost controller, I was really hoping to break into the 13's with the boost turned up and using my slicks
I heard that the oem fuel system is good up to 220 whp tho? This is prolly a noob question...
I ran a 13.6 with a 1.5 SOHC, so its doable, just needs to be tuned right. And get yourself some bigger injectors if you're going any higher on boost.
listen to everybody you need bigger injectors and fuel pump.
tuning is the key to keep a health motor.
pbzhb
Feb 20, 2008 07:53 AM
Snail Tuning
May 15, 2004 07:42 PM
SiBirdie
Nov 8, 2003 05:15 PM
