d16z6 mini me swap questions
ok i have a 90' dpfi crx i am doing the d16z6 head swap w/ vtec
questions:
can i keep my current timing belt if i keep the cam gear off of my d15 head
with a rywire.com harness conversion and obd-1 conversion harness it should just be bolt on and then plug and play right?
is this all i need:
-converted harness
-head w/ vtec solenoid
-p28 ecu
-intake w/ rail and injectors
-d16 dizzy
-d16 head gasket
....etc...
the only technical difference than a regular head swap i just have to pop out that plug in the block so the vtec can activate right?
questions:
is this all i need:
-converted harness
-p28 ecu
-d16 dizzy
-d16 head gasket
....etc...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwill_2004 »</TD></TR><TR><TD CLASS="quote">whats he mean pop out the plug in the block so the vtec can activate?</TD></TR></TABLE>
On the non vtec blocks, there is an oil control jet located in the block between the #2 and #3 cylinders. If you don't remove it, you won't have enough oil pressure to the head to activate vtec.
DelSols-plural
Sep 13, 2011 06:17 AM
thaiboiz
Dec 23, 2006 05:57 AM
