How high can i rev???
i am palnning to build a b18c with ls crank, Stage 2 valavtrain and cams also, i wanna kno how high can i rev wid stock block wid ls crank???
Modified by djstain at 7:24 PM 8/11/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djstain »</TD></TR><TR><TD CLASS="quote">ls crack</TD></TR></TABLE>
damn that ***** gunna be fast!
I have a gsr with low comp pistons (previous owner put them in replacing them soon) skunk2 stage 2 cams, skunk2 valves, springs, and retainers, SK2 cam gears, stock crank and a few other things (look in my garage for the rest of the parts) and I rev to 9K every gear when I am in the mood. No problems yet. Here soon I will probably bump the rev limiter to 9500, and stop there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djstain »</TD></TR><TR><TD CLASS="quote">can i rev to 9k rpm safely? wat else would i need in order to rev so high?</TD></TR></TABLE>
cams that make power that high
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djstain »</TD></TR><TR><TD CLASS="quote">wid my above setup, is it better to run ls rods or GSR rods???</TD></TR></TABLE>
use ls rods if you use an ls crank
you can't use gsr rod with ls crank ( jornal bearing dif in size).
Blind-Fashion
Aug 4, 2004 01:31 AM
