14 degrees BTDC + or - 2 degrees? no color?
Old Aug 9, 2006 | 04:22 PM
white90crxhf's Avatar
Default 14 degrees BTDC + or - 2 degrees? no color?
trying to set the timing on my HF, manual says 14 degrees BTDC + or - 2 degrees... for the STD and SI it gives a color...for mine it doesnt...which mark is 14 degrees? or should i set the timing gun to 14 degrees and line it up with the white mark?
Also that stupid thing i need to short... is the part the wires go into blue? is it right next to the blower motor?
Old Aug 9, 2006 | 05:07 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: 14 degrees BTDC + or - 2 degrees? no color? (white90crxhf)
See: https://honda-tech.com/zerothread?id=1698225
the one in the middle of three with the gun on zero
or use the advance **** and the tdc mark..
hmtcrxsir
Apr 10, 2017 08:01 AM
B16Civic93
Mar 5, 2005 10:32 PM
handa
Oct 24, 2004 08:27 AM
fe519
Nov 10, 2003 08:32 PM
dubnine
Sep 16, 2002 01:35 PM
