is this the timing.
Old Aug 8, 2006 | 08:26 PM
SoHc94's Avatar
Default is this the timing.
94 civic ex with a 1.6 l vtec. new dis cap new starter new radiator. lol whatever. but when we try and crank it over it would (not) fire. so we checked the fuel reg which was clogged. so i got a new one. it still doesnt start. we think the timing is off. because it doesnt smell like gas. but i need to know if this is prolly the timing being off or if it could be sumthng else....
aim: johnxdeere 22
405-706-2062
Old Aug 8, 2006 | 08:29 PM
potential's Avatar
Default Re: is this the timing. (SoHc94)
i cant understand a word u said.
Old Aug 8, 2006 | 08:53 PM
solerizr's Avatar
Default Re: is this the timing. (potential)
Il rephrase that for SoHc94, just for fun.
I have a 94 civic ex with a 1.6 liter VTEC. It has a new distributor cap, new starter, and a new radiator, however when i try to crank it over it wont fire, so i checked the fuel regulator, which happened top be clogged, and got a new one, and it still wont start. I think the timing is off, because i dont smell gas, however im not sure. What do you think: is the timing off or should i try something else to get it to start?
Old Aug 8, 2006 | 09:13 PM
del_slow420's Avatar
Default Re: is this the timing. (solerizr)
do u have comp fuel and spark?
Old Aug 8, 2006 | 09:16 PM
BluLude's Avatar
or no injector pulse because you dont smell gas, the more important question here is, was the car running before you did all the stuff to it, if it was I doubt its the timing, btw if the timing is off you could still smell gas, but being unable to smell gas is a horrible way to diagnose a car, I would let a mechanic take a look at it to save you some grief but if you want to do it on your own, check to see if there is spark, and to see if the plugs are wet, and to see if the injectors pulse first.
Old Aug 8, 2006 | 09:23 PM
98-00's Avatar
Default Re: is this the timing. (BluLude)
make sure your hooked up in correct firing order.
firing order goes clock wise 1-3-4-2 starting from the bottom left of the distributor cap going clockwise.
Ty Dyer
Feb 26, 2017 02:58 PM
Loy
Dec 31, 2014 07:56 AM
jonnybadboi9
Jul 15, 2009 09:39 PM
go2sleep
May 30, 2007 12:53 PM
C ronic
Apr 8, 2003 08:03 PM
