84mm sleeved block (b20vtec)?!?
Old Aug 8, 2006 | 08:08 PM
tobe1424's Avatar
Default 84mm sleeved block (b20vtec)?!?
On an 84mm gsr or ls block with ls crank....with high compression pistons and gsr head...how would the valve to piston clearance be affected....isnt bad already with a b20 block....you with some 11+ c/r.... I need to get my mind straight to start getting **** together...thanks
Old Aug 8, 2006 | 08:09 PM
Luserkid's Avatar
Default Re: 84mm sleeved block (b20vtec)?!? (tobe1424)
We have a B20/VTEC with 12.5c/r pistons on a 85mm sleeved with flat valves and never had a problem.
Old Aug 8, 2006 | 08:10 PM
tobe1424's Avatar
Default Re: 84mm sleeved block (Luserkid)
on what block... and with an ls crank right...
Old Aug 8, 2006 | 08:13 PM
del_slow420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tobe1424 &raquo;</TD></TR><TR><TD CLASS="quote">On an 84mm gsr or ls block with ls crank....with high compression pistons and gsr head...how would the valve to piston clearance be affected....isnt bad already with a b20 block....you with some 11+ c/r.... I need to get my mind straight to start getting **** together...thanks</TD></TR></TABLE>
so what block/crank/rods combo u using and ill tell u the clarence
Old Aug 8, 2006 | 08:32 PM
tobe1424's Avatar
Default Re: 84mm sleeved block (del_slow420)
well now that i think about it....with an 84mm gsr block or ls block....what crank/rod combonation do u need...i mean if you keep it ls crank and rods ithink there would be clearance issue....correct me if im wrong
Old Aug 8, 2006 | 08:51 PM
Default Re: 84mm sleeved block (tobe1424)
the ls and b20 both have the same cranks and rods just the b20 is bored to 84mm u can use the ls crank with the b20 but not the gsr if u do 84mm gsr u need gsr rods and crank the gsr-ls is a 81mm block u would have to get sleeved and bored
Old Aug 9, 2006 | 04:54 AM
tobe1424's Avatar
Well yea...thats what I was originally asking...with a 84mm bore gsr or ls block....if i use high c/r pistons with a gsr head and ls crank and rods do a would there be any clearance....because yea 84mm is the right bore to achieve a 2.0...but i would also need a different stroke...which ls and b20 have.....like when ppl go ls/vtec and stuff like that....but just wanna know about clearane
Old Aug 9, 2006 | 07:21 PM
tobe1424's Avatar
bump
Old Aug 9, 2006 | 07:30 PM
u are saying gsr or ls block with ls crank are u building a gsr or a lsvtec the ls block u use ls crank and rods gsr u use gsr rods and pistons....
Old Aug 10, 2006 | 02:10 PM
tobe1424's Avatar
doesnt really matter...its the same block...one has oil squirters the other one doesnts....thats why im sayin "or"
haroldthefly91crx
Nov 23, 2007 01:09 PM
PowerHouse
Nov 16, 2004 04:04 PM
crashtest Sonny
Jun 3, 2003 05:25 AM
untitled
May 14, 2003 07:51 AM
Boostless97Lude
Nov 20, 2002 09:11 PM
