Help!!! Rattling in rear of car..
Old Aug 8, 2006 | 04:39 PM
jdmcrx1's Avatar
Default Help!!! Rattling in rear of car..
Ok, I have a 95 4 door accord I just traded for my civic. it was dropped previously to my ownershp and there is a clunk/rattle when going over bumps.
I thought maybe something is not tight. so in being a pretty good suspension guru I took the whole suspension apart and put grease on all the bushings, put in new struts tower caps and bushings, then retorqued EVERYTHING to spec. it is lowered on tokico blues w/ sportline springs.
I took the whole rear interior out thinking that might be the case, but still a rattle.
I was told some of the rear decklids like to come loose from the spot welds but all are intact and have never been touched.
I had someone else drive and it sounded like it was coming from the strut tower but everything it tight.
I really cant figure this out and any help would be greatly appreciated.
-Tony
402-301-5962
Old Aug 8, 2006 | 10:36 PM
jdmcrx1's Avatar
Default Re: Help!!! Rattling in rear of car.. (jdmcrx1)
nobody has had this problem??
-Tony
Old Aug 9, 2006 | 12:03 AM
Jmumblez2001's Avatar
check your rear brakes maybe a piece of metal broke in there. i had an 88 accord that did that. most likely i'm wrongbut check anyway
Old Aug 9, 2006 | 10:26 AM
jdmcrx1's Avatar
Default Re: Help!!! Rattling in rear of car.. (Jmumblez2001)
just checked the brakes and replaced all the hardware and shoes.. no problem there.. I am thinking it is the spring botoming out. it looks as if the spring is binding just sitting in the driveway..
-Tony
Old Aug 9, 2006 | 10:39 AM
TouringAccord's Avatar
H-T Order of Merit
Is it more of a clunk or a rattle? Or does it clunk and then rattle?
Just a couple thoughts...
I'm not sure but with those springs/struts do the bump stops need to be cut? If so, did you verify they were cut to the proper length? It could be bottoming out on those.
Also, I've heard of people say that there exhaust would hit the lower control arm with aftermarket exhausts and lowered suspensions. Is the exhaust aftermarket performance or has it been replaced lately? Check to make sure the hangers are holding the exhaust in the right place, far enough away from possible contact.
Old Aug 9, 2006 | 11:07 AM
jdmcrx1's Avatar
Default Re: Help!!! Rattling in rear of car.. (TouringAccord)
I did cut the bump stops to fitment.. The person who lowered it did not. I think the exhaust might have a small part to do with it but it should be far enough away not to touch anything..
it is a clunk then rattle...
-Tony
Old Aug 10, 2006 | 06:39 PM
briq4's Avatar
My little cousin had a 96 before she smashed it up, her noise from the rear was a busted sway bar mount. Made a lot of noise but only on odd bump and turn combinations. Something to check.
Old Aug 10, 2006 | 06:50 PM
Tech-Nics's Avatar
do you have a spoiler on the car???
just asking cause spoilers like "touring style" or any in the lines of that, that have the supports twards the middle tend to bend on the corners and make a clunk/raddle sound....
i know that sounds weird, but i have the same people with my 97 lx coupe when i hit bumps and my car is lowered on adjustable coilovers...it could be the bumper itself...i dont know....now im very curious aswell cause im so use to that clunk raddle sound that i want to really know what that can be.
Old Aug 11, 2006 | 07:59 AM
jdmcrx1's Avatar
Default Re: (Tech-Nics)
I do not have a spoiler and I didnt think this car had a sway bar.. I have owned civics most my life but I honestly didnt know what models of Accords had sway bars and which didnt.
I dont see any sway bars but I could be wrong.. I have a 95 lx if that helps any.
I appreciate your thoughts guys. someone has to have the answer out there.. lol
-Tony
Old Aug 11, 2006 | 01:51 PM
briq4's Avatar
Default Re: (jdmcrx1)
95 LX didn't have a sway bar so probably not going to be the issue. Sorry.
Old Aug 11, 2006 | 05:15 PM
jdmcrx1's Avatar
Default Re: (briq4)
It's ok, I appreciate you input though!... I got a set of coulovers and am going to try those and see if it's the springs. if it is, I will let you know..
The odd thing is I have put many sets of sportlines on accords and never heard of this problem.. unles these springs are COMPLETELY worn out..
THanks guys I will let you know what happens
-Tony
Old Aug 12, 2006 | 12:42 PM
jdmcrx1's Avatar
Well, I put on the coilover and it fixed all my rattling and clunking problems.. I guess the sportlines had seen better days. They had settled past their specs so they were rubbing the coils together..
Thanks guys for all your help..
-Tony
Kat620
Jan 18, 2012 11:20 AM
Lek
Honda Civic (2006 - 2015)
Jun 19, 2010 07:16 PM
phikshin
Suspension & Brakes
Jun 11, 2009 12:03 AM
blackakkord
Sep 11, 2008 10:44 AM
Ryan T
Suspension & Brakes
Apr 28, 2005 04:16 PM
