s20 tranny making noise
Old Aug 8, 2006 | 12:25 PM
v8killa91's Avatar
Default s20 tranny making noise
every time i put my car in first and start to go it sounds like im in reverse...wtf i dont understand. help please also its making a noise when i decelrate like a waaaana na na na help pissin me off.
Old Aug 8, 2006 | 12:30 PM
EK k kay's Avatar
Default Re: s20 tranny making noise (v8killa91)
Bad bearing. Does the sound go away when you push in the clutch?
Old Aug 8, 2006 | 12:36 PM
v8killa91's Avatar
Default Re: s20 tranny making noise (EK k kay)
yea dude....i just bought a clutch kit comes with all the bearings. will that stop the noise?
Old Aug 8, 2006 | 12:44 PM
v8killa91's Avatar
bump help help
Old Aug 8, 2006 | 12:46 PM
turboxsi's Avatar
From the sound of your symptoms it sounds like its your input shaft bearing is going bad ( i have the same problem now), which is a common problem with honda trannies. BauleyCivic has a thread https://honda-tech.com/zerothread?id=596873 on how to change out this bearing.
Old Aug 8, 2006 | 12:58 PM
EK k kay's Avatar
Default Re: s20 tranny making noise (turboxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboxsi &raquo;</TD></TR><TR><TD CLASS="quote">From the sound of your symptoms it sounds like its your input shaft bearing is going bad ( i have the same problem now), which is a common problem with honda trannies. BauleyCivic has a thread https://honda-tech.com/zerothread?id=596873 on how to change out this bearing.</TD></TR></TABLE>
Yup. The input shaft bearing is going. I had that problem a while back. While you're in there you might as well change out the main shaft bearing because they usually go out at the same time.
Old Aug 8, 2006 | 01:02 PM
v8killa91's Avatar
not that kinda noise. its in first and when decelrating between gears. like wha=en i push the clutch in then slowly let it out it whinessoon as it engages bam it goses away. i dont understand? help
Old Aug 8, 2006 | 03:10 PM
v8killa91's Avatar
bump help!
Old Aug 10, 2006 | 01:12 PM
v8killa91's Avatar
bump
RG400SmartTowel
Transmission & Drivetrain
Oct 22, 2009 06:18 PM
mayfly
12
Aug 4, 2009 04:09 PM
crxgator
Oct 2, 2006 02:06 PM
StreetOne
Sep 7, 2004 03:49 AM
boostinb20vtec
Apr 22, 2004 04:32 PM
