D16Y8 Intake manifold on Y7 head questions
Old Apr 24, 2002 | 11:35 AM
HENRY's Avatar
New User
Default D16Y8 Intake manifold on Y7 head questions
I need to know what you need to swap a Y8 intake manifold over to the Y7. What parts are needed from the Y8 and what are retained from the Y7? Are the only things you need the manifold itself, IAC, and gaskets? What about the sensors? I know you can keep the Y7 throttle body but is there anything to be gained from swapping to the Y8 TB? TIA
Old Apr 24, 2002 | 08:49 PM
SCsol's Avatar
Default Re: D16Y8 Intake manifold on Y7 head questions (HENRY)
you will be getting a bigger TB and better runner so its worth the swap and is very easy to do
Old Apr 24, 2002 | 09:10 PM
Soku1kcivic's Avatar
Default Re: D16Y8 Intake manifold on Y7 head questions (lowsol)
everything should be the same the IAC plug is the same. so its like a plug and play put remember to replace the gasket
Old Apr 24, 2002 | 09:15 PM
non vtec's Avatar
Default Re: D16Y8 Intake manifold on Y7 head questions (Soku1kcivic)
i was thinking about doing this swap as well...what's an IAC? don't you need the cams from the Y8? and the ECU?
Old Apr 29, 2003 | 09:59 PM
Mr. Thunderlips's Avatar
Why are you doing this?
Old May 14, 2003 | 04:07 PM
pornstarSR's Avatar
i just got my hands on the same thing...and im trying to figure how its gona wire up, everything but the IAC valve is fine....the IAC on a 96-2000 civic DX is a 3 wire.....Ex is 2 wire......not sure how this is gona work
Old May 14, 2003 | 06:19 PM
Turbo Powa's Avatar
Default Re: D16Y8 Intake manifold on Y7 head questions (pornstarSR)
if the iacv is on the tb then just swap over to thy7 tb on the y8 manifold.
Old May 14, 2003 | 07:31 PM
hatchback19's Avatar
Default Re: D16Y8 Intake manifold on Y7 head questions (Panda EK)
http://www.makuragi.s5.com/civic_99/Y8maniswap/
Good luck
Old Jun 12, 2003 | 02:02 AM
dubniK's Avatar
Default Re: D16Y8 Intake manifold on Y7 head questions (hatchback19)
that webpage was EXCELLENT.. to you!!
freddy chavez
14
May 30, 2013 08:55 PM
devonic
Nov 26, 2009 07:45 PM
redpeppers
Sep 17, 2005 10:28 PM
EK k kay
48
Nov 16, 2004 05:01 AM
