y8 intake manifold swap question.
Old 10-30-2004, 09:05 PM
EK k kay's Avatar
Default y8 intake manifold swap question.
So I'm going to swap a y8 intake manifold onto my y7 head. I am going to use my y7 throttle body. Do I need a new throttle thingy (the bronze/gold thing that spins on the tb)? Or can I use the one on my y7 tb? Thanks
civictildeath's Avatar
Default Re: y8 intake manifold swap question. (chowmien)
it will be fine without changing it
Old 10-30-2004, 09:07 PM
EK k kay's Avatar
Default Re: y8 intake manifold swap question. (civictildeath)
^you sure? Aren't you the guy that didn't know what a longblock or shortblock was?
Old 10-30-2004, 09:14 PM
i said that to **** people off. i do know what im talking about or i keep my mouth shut for helping other people
Old 10-30-2004, 09:31 PM
EK k kay's Avatar
Ok so can anyone else vouch for this? Thanks
Old 10-30-2004, 09:53 PM
fishnfst's Avatar
You need the one off of a y8 tb. The y7 was made to be used vertically the y8 has a horizontally mounted throttle body...
Old 10-30-2004, 09:56 PM
Default Re: (fishnfst)
ok i did not know that
Old 10-30-2004, 09:57 PM
fishnfst's Avatar
Then why are you here spreading misinformation like its the truth????
Old 10-30-2004, 10:05 PM
cause everything ive read says it will bolt up
Old 10-30-2004, 11:48 PM
DRIVENRacing's Avatar
lol... good luck on the swap
Old 10-31-2004, 01:45 AM
murmur9's Avatar
Default Re: (TurboHybridEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst &raquo;</TD></TR><TR><TD CLASS="quote">You need the one off of a y8 tb. The y7 was made to be used vertically the y8 has a horizontally mounted throttle body...
I can vouch for that!!!!! I tried to use a y7 TB on a y8 IM , it dosnt work right, they are set at different angels or some ****. grab you a y8 tb
Old 11-11-2004, 12:53 PM
d16rice's Avatar
Y7 throttle body does NOT work on Y8 intake manifold. I tried it. I does bolt right up, but the butterfly flap opens in the opposite direction; there is no way to loop the throttle cable.
Old 11-11-2004, 01:30 PM
Mwsol's Avatar
Default Re: y8 intake manifold swap question. (d16rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16rice &raquo;</TD></TR><TR><TD CLASS="quote">Y7 throttle body does NOT work on Y8 intake manifold. I tried it. I does bolt right up, but the butterfly flap opens in the opposite direction; there is no way to loop the throttle cable.</TD></TR></TABLE>
Well I guess im a lil different then you... I looped it the right way and it worked.
Slam!
Old 11-11-2004, 01:35 PM
steve0unce's Avatar
i put a y7 on my manifold too..weird for some reason it works
Old 11-11-2004, 02:19 PM
HitEm'Up's Avatar
U have to modify the bracket holding the cable.
Old 11-11-2004, 02:32 PM
bambbrose's Avatar
http://www.parkinginlots.com/d...p.htm
I made this a while back
Old 11-12-2004, 04:39 PM
d16rice's Avatar
Default Re: (bambbrose)
Looks kind of weird, but I guess if it works, then its fine.
I, on the other hand, don't want to tamper with makeshift throttle control. The original design is pretty clean, and that's what I'm going for.
Your write up is very helpful non the less.
Old 11-13-2004, 01:42 AM
bambbrose's Avatar
yea the ls peice was just temporary, until the local dealership got a Y8 one for me. It was like 8.30 or something like that
Old 11-13-2004, 02:23 AM
Calvinator's Avatar
Of course you "can" use the y7 plate, but it will lead to problems in the future. Just get it done right the first time.
Old 11-13-2004, 06:48 AM
colinproctor's Avatar
Default Re: (xtremeazian)
just put the y8 TB on it and be done with it
Old 11-13-2004, 08:43 AM
bambbrose's Avatar
putting the Y8 throttle body would require you to use the Y8 IACV, problem is the Y8 IACV is a 2 wire IACV, therefore won't work with your d16y7 ecu. You have to use the Y7 throttle body with the built in IACV
Old 11-13-2004, 09:15 AM
EK k kay's Avatar
Thanks. I just went and bought the throttle spring along with an auto y8 throttle body. Too bad the tps sensor is broken and there's no way of replacing it otherwise I could have just used it. $13 isn't bad for that.
Old 11-13-2004, 09:27 AM
Calvinator's Avatar
Default Re: (chowmien)
Good luck on the install...I hope it goes smooth
Old 11-14-2004, 07:50 PM
mugencivic4dr's Avatar
your going to have a vacuum leak after you put the manifold on...
Old 11-14-2004, 08:01 PM
bambbrose's Avatar
lol an why is that
Quick Reply: y8 intake manifold swap question.
