Fried something! Fuel pump wont prime...
To keep things short, i messed up on the injector wiring for dsm injectors on a 97 prelude. Had one of the cables switched.
Now car doesnt start.
-No fuel pump prime when i turn car on ON.
-Replaced main relay.
-Tried stock ecu and same results.
-I noticed though that when i hook up my p28 with s200b the little red LED on the hondata unit does not come on, even with a brand new interface cable.
-Checked all fuses
Anyone know what the hell is going on??? Why wont the fuel pump come on???
-Checked all fuses
i suppose its there by all the other fuses? ill check if i can find it.
edit: ahh guess u meant the fuse box under the hood. every fuse is fine.
check all the ground wires. especially the one that connects to the thermostat. check the ECU fuses. and run power directly to the fuel pump and test if its good. if nothing..then you probably shorts some wires. good luck!
thanks for the input guys, friend of mine figured it out. Main relay wasnt getting power for some reason.
