JDM gauge cluster install issue
Old Aug 6, 2006 | 05:58 PM
integragsr6's Avatar
Default JDM gauge cluster install issue
I recently got the JDM gauge cluster from 94-96 integra. My ride is a 97-01 integra and I'm having trouble wiring up the gauge cluster. In the pic below is a yellow plug on the left side of this pic, does anyone know what that plug is for? Also, does anyone know if I remove the gauge faces (temp, rpm, speedo, and fuel) from my old gauge cluster and replace it with the JDM gauge faces, will that work? Anyone who has experience, please let me know. Thank you
Old Aug 6, 2006 | 06:05 PM
94_DC4's Avatar
Default Re: JDM gauge cluster install issue (integragsr6)
Yellow plug is for the SRS(Airbag) system.
Old Aug 6, 2006 | 06:08 PM
shyboi4u's Avatar
Default Re: JDM gauge cluster install issue (SiRGDC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRGDC &raquo;</TD></TR><TR><TD CLASS="quote">Yellow plug is for the SRS(Airbag) system.</TD></TR></TABLE>
Old Aug 6, 2006 | 07:22 PM
aznvietboi87's Avatar
taking off the gauge faces and putting it on the old cluster would work too.
Old Aug 6, 2006 | 08:05 PM
Default Re: (aznvietboi87)
Which is the better solution to remove the gauge faces and replace it with my old cluster shell or to rewire the cluster with the JDM version? Does having the SRS plug make a difference because the JDM cluster doesn't have the SRS plug on the back.
Old Aug 6, 2006 | 08:41 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (integragsr6)
Did anyone catch this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integragsr6 &raquo;</TD></TR><TR><TD CLASS="quote">I recently got the JDM gauge cluster from 94-96 integra. My ride is a 97-01 integra and I'm having trouble wiring up the gauge cluster.
The reason to swap flim or gauges is to do a 94-97 or 98+ swap. If this is a 94-97 cluster and your car is a 98+. Or going to need to either:
1. Swap green flims
2. Or use the JDM gauges in your US cluster.
Either way is really easy, I had a 98+ cluster into my 00 teg and it still didn't work right. So I used some of the mad tight jdm symbols and the gauges, put all this into my US cluster. Worked out great. PM me if you have anymore questions.
Old Aug 6, 2006 | 09:54 PM
BlueIntegraBoy's Avatar
Might as well swap the gauges into the USDM housing since you'll be removing the screws in the back no matter what. Don't forget to swap over the bezel and the USDM light icons (the right two and the left bottom) onto the JDM bezel.
Old Aug 6, 2006 | 10:41 PM
crapanese's Avatar
jusr did this swap in my car a week ago. just swap out the guages themselves into your cluster thats what i did. works great
Old Aug 6, 2006 | 10:48 PM
Naruto's Avatar
Default Re: (00IntegrAllmotoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">Did anyone catch this?
Yeah I caught it But the years go 94-97 and 98-01. JDM is a lil different of course, so I have no idea what specific year grouping his car is in.
Old Aug 7, 2006 | 09:59 AM
crapanese's Avatar
Default Re: (Naruto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naruto &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah I caught it But the years go 94-97 and 98-01. JDM is a lil different of course, so I have no idea what specific year grouping his car is in. </TD></TR></TABLE>
who cares. just swap out the plastic at first then. to see if it works. it only takes literally 5 mins.
Old Aug 8, 2006 | 07:39 AM
Default Re: (crappyDC4)
Thanks for the help. I actually got it to work and it's beautiful. The only thing that's bugging me now is the odometer is higher than my normal millage and it's in km/h instead of mph. Any suggestions? Overall a great mod.
Old Aug 8, 2006 | 10:52 AM
HT Black OPs
search, theres a nice write up on how to roll back odometer. Make sure when you roll it back you convert your origanl mph to kmh.
Old Aug 8, 2006 | 09:48 PM
94rs-turbo's Avatar
this has only been covered like 10 billion times search bro swap out the actual gaues and the 2 lens on the bezel on the right side thats it and thats all
Old Aug 8, 2006 | 10:55 PM
Built Beast's Avatar
Default Re: (94rs-turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo &raquo;</TD></TR><TR><TD CLASS="quote">this has only been covered like 10 billion times search bro swap out the actual gaues and the 2 lens on the bezel on the right side thats it and thats all</TD></TR></TABLE>
reading owns you...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integragsr6 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the help. I actually got it to work and it's beautiful. The only thing that's bugging me now is the odometer is higher than my normal millage and it's in km/h instead of mph. Any suggestions? Overall a great mod.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">search, theres a nice write up on how to roll back odometer. Make sure when you roll it back you convert your origanl mph to kmh.</TD></TR></TABLE>
correct, here is the link...(pics don't work anymore and it is on a civic cluster but the exact same thing essentially)
https://honda-tech.com/zerothread?id=784476
and AGAIN...DON'T FORGET TO CONVERT YOUR MILEAGE TO KM BEFORE RESETTING IT
At the bottom of this link there is a converter that will do it for you real quick...
http://www.ff-squad.com/tech/temp/Bgears.htm
hope this helps
Old Aug 12, 2006 | 03:25 PM
Default Re: (Built Beast)
Thanks for all the help here. Sometimes searching works only if you know the keywords to use. Trust me, I've tried and that's why I asked because I couldn't find anything. Plus that's how we learn by asking. Again thanks for all the help guys.
f575gtc
Honda Civic (2001 - 2005)
Jan 16, 2015 01:48 PM
JDM_WHR
Jun 13, 2009 11:42 AM
NsX_CrX
Feb 11, 2005 10:12 PM
SpoonFed
Nov 15, 2001 09:34 AM
