left pads worn completely, right pads have plenty meat
Old Aug 6, 2006 | 11:01 AM
Boostage's Avatar
Default left pads worn completely, right pads have plenty meat
Just did the brakes on my 94 non abs ej1. and the driver side was completely worn out but passenger side looked almost new. the calipers are new autozone calipers, I guess remanufactured. I am running an ITR brake booster and master cylinder and GSR rear discs. goodridge SS lines. is this a prop valve problem.
BTW the reason I have new calipers is because the old ones did the same EXACT thing.
Old Aug 6, 2006 | 11:14 AM
Rock Meathammer's Avatar
Default Re: left pads worn completely, right pads have plenty meat (Boostage)
Does the car pull to the left when you brake?
Old Aug 6, 2006 | 11:16 AM
Boostage's Avatar
Default Re: left pads worn completely, right pads have plenty meat (B20 EJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20 EJ6 &raquo;</TD></TR><TR><TD CLASS="quote">Does the car pull to the left when you brake?</TD></TR></TABLE>
it did with the old calipers, but now it stays straight under hard braking.
Old Aug 6, 2006 | 11:18 AM
Well, with uneven pad wear generally comes pulling. Is the pad wear still uneven, even after you have changed the calipers?
Old Aug 6, 2006 | 11:19 AM
Do you have SS lines in place of the hardlines or the hoses?
Paxil4x4's Avatar
brake line might be swelling and it not allowing the caliper tp release fully
Old Aug 6, 2006 | 11:50 AM
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20 EJ6 &raquo;</TD></TR><TR><TD CLASS="quote">Well, with uneven pad wear generally comes pulling. Is the pad wear still uneven, even after you have changed the calipers?</TD></TR></TABLE>
Yes I just changed them today and the driver side was lower by alot
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20 EJ6 &raquo;</TD></TR><TR><TD CLASS="quote">Do you have SS lines in place of the hardlines or the hoses?</TD></TR></TABLE>hoses
satintegra
Jun 23, 2008 08:33 PM
tarheelsoldier
May 25, 2006 10:12 PM
P@@RB@Y
Mar 5, 2006 06:06 PM
blueturboteg
Dec 3, 2003 03:27 PM
