Where do you mount your gauges?
Old Aug 5, 2006 | 08:04 PM
BrOkEn_Dc2's Avatar
Default Where do you mount your gauges?
I'm about to start doing some major modifications to my Gsr. I'll be adding a turbo and so on and was planning on getting Air/fuel - Boost - Oil Temp. - EGT. Just woundering where you guys mount your gauges.
SHOW PICTURES!
SHOW PICTURES!
----I'm A.D.D. and I need PICTURES!
Old Aug 5, 2006 | 10:00 PM
jared99's Avatar
Default Re: Where do you mount your gauges? (Spoon07)
I mounted mine on the pillar. Although then people will know you have something under the hood. I don't have any pics but you can see it in this video, the bottom EGT gauge came disconneccted so it's not lit.
http://s68.photobucket.com/alb...9.flv
Old Aug 6, 2006 | 08:31 AM
IN VTEC's Avatar
In front of the clock on the dash. It makes them easy to read and it doesn't hinder vision.
Old Aug 6, 2006 | 09:41 AM
mattcivic's Avatar
Default Re: Where do you mount your gauges? (IN VTEC)
boost, pyro, oil temp, water temp, oil presure, & wideband. i plan on getting a A/F guage from autometer and getting the converter that runs through my plx m300 to convert it into a wideband then get a dual pod to put on the flat part of the dash in frotn of the clock and add an AIT sensor as well.
Old Aug 6, 2006 | 10:06 AM
jdmotorsports's Avatar
Default Re: Where do you mount your gauges? (mattcivic)
i've got a 3 gauge pillar pod that will fit the g3 2 door integras for sale.
i had a big tach and 2 gauges but am getting rid of them. Blox sells a tach that fits in the small gauge pods, so that will look nicer.
Old Aug 7, 2006 | 06:21 AM
ithrowpoop's Avatar
Default Re: Where do you mount your gauges? (jdmotorsports)
my guages are mounted where the cruise control and dimmer switches are.
Old Aug 7, 2006 | 07:09 AM
DC4_2nr's Avatar
I think that replacing the dimmer and curise control switches with gauges, gives a clean look. also, using a gauge cluster bezel to house 2 additional gauges is pretty trick too. I mounted a shift light on top of the steering colum, I wanted a monster tach, but 1) they are the singel most stolen part on cars, and 2) its usuially a BIG hint that you have something going on under the hood
Old Aug 7, 2006 | 11:18 AM
DSEA2's Avatar
Default Re: Where do you mount your gauges? (DC4_2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4_2nr &raquo;</TD></TR><TR><TD CLASS="quote">I think that replacing the dimmer and curise control switches with gauges, gives a clean look. also, using a gauge cluster bezel to house 2 additional gauges is pretty trick too. I mounted a shift light on top of the steering colum, I wanted a monster tach, but 1) they are the singel most stolen part on cars, and 2) its usuially a BIG hint that you have something going on under the hood</TD></TR></TABLE>
and 3. theres no point on a street car that already has a tach.
EDIT: why the hell would anyone steal a monster tach...
Old Aug 7, 2006 | 11:46 AM
JoePSI's Avatar
Default Re: Where do you mount your gauges? (SpoonDC4)
I put my boost gauge where my Cruise control button is on my DC2, Nice stock look.
Old Aug 7, 2006 | 03:56 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcivic &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
That dash is busier than a one-legged man in an ***-kicking contest.
Old Aug 13, 2006 | 01:37 PM
BrOkEn_Dc2's Avatar
Default Re: Where do you mount your gauges? (Dogginator)
I like how the dash looks really busy and all. I'm just afraid to drill into my dash.
Where is a good place to mount a shift light (ONLY LIGHT NOT MASTER TACH)?
I think I saw it on team-integra.com where the guy mounted it where the fuse box cover is. Do you think I will be able to see it down there?
Old Aug 13, 2006 | 02:47 PM
stocker2shocker91's Avatar
I requested a short story for a title.
more pics.
any G2s??
Old Aug 13, 2006 | 03:07 PM
enil01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon07 &raquo;</TD></TR><TR><TD CLASS="quote">Where is a good place to mount a shift light (ONLY LIGHT NOT MASTER TACH)?
I think I saw it on team-integra.com where the guy mounted it where the fuse box cover is. Do you think I will be able to see it down there?</TD></TR></TABLE>
In the heater vents can be pretty cool.
Old Aug 16, 2006 | 09:09 AM
BrOkEn_Dc2's Avatar
Default Re: Where do you mount your gauges? (enil01)
I think I've decided to buy a Wideban AF - Boost - Oil pressure - EGT - and maybe a Oil temp or water temp.
I'll probably end up mounting them in a cluster brezel and either on a 3 gauge pillar pod or where the cruise control and dimmer switches are for a clean sleeper type look.
Let me know what you think and show me some more pictures. lol
Old Aug 16, 2006 | 03:49 PM
yee SERIOUS's Avatar
don't go gauge crazy. all you need is wideband o2, boost gauge, oil pressure, and egt. those are the best to have. oil temp and water temp is resourceful, but not necessary.
there's only a few circular gauge wideband o2 sensors like AEM's uego, if you get the box kind like PLX, then you don't even need a gauge pod for it.
i'll try to take a picture of mine tonight for you. i have 2 on the A-pillar bar and 2 on the cluster bezel.
Old Aug 16, 2006 | 04:21 PM
Default Re: (undercoverdc2)
actualy you dont even realy need a wideband o2 unless your tuning it all the time. a egt will alert you to anything going bad, but both are not needed everyday.
Old Aug 17, 2006 | 03:40 PM
Flexin5's Avatar
i have mine on the piller. autometer 2gage pod. it can kinda get in the way, i almost hit a pedestrian when i first got it
Old Aug 17, 2006 | 05:35 PM
TURBODC4TEG's Avatar
Default Re: (Flexin5)
glove box, arm rest, under radio
The_Honda_Guy
10
Feb 13, 2010 01:17 PM
beat
Honda S2000
36
Jan 17, 2009 04:54 PM
hondaboy4life
Apr 6, 2006 12:35 PM
orion840
May 10, 2005 08:10 PM
KCHybrid
Jan 7, 2003 10:22 AM
