Honda S2000 Honda S2000
Where to put Gauges
Old Jan 15, 2009 | 05:59 AM
beat's Avatar
Default Where to put Gauges
Hi,
My friend has an AP2 and he is getting the Vortech kit.
I wonder where you guys put your gauges as there is very limited space to put gauges in the S2k.
Old Jan 15, 2009 | 06:12 AM
Chris.'s Avatar
Honda-Tech Order of Merit
Default Re: Where to put Gauges
i guess it depends on how many gauges he has.
1. they make a-pillar gauge pods for the s200o i believe
2. cut into the dashboard and mount there (possibly where the cruise and rear defroster buttons are)
3. ricks2k gauge pod, except that its a ripoff
http://www.ricks2k.com/products/gaugeset.php
Old Jan 15, 2009 | 06:15 AM
beat's Avatar
Thanks for the reply.
1. Not interested in a pillar ones.
2. Do you have pics?
3. It is a rip off and its ugly.
Old Jan 15, 2009 | 06:46 AM
SuzukaBlueAP2's Avatar
just curious, but, what gages is he/she going to install?
When I installed my Comptech kit I purchased a 2-pod a-pillar and put a boost and oil pressure gage in it. The boost is pretty much a waste and will be replaced by a wideband O2.
Old Jan 15, 2009 | 06:47 AM
beat's Avatar
Boost, oil temp, oil press, water temp, exhaust temp. air fuel
Old Jan 15, 2009 | 07:10 AM
Chris.'s Avatar
damn thats gonna be tight to fit in there. maybe if he got a digital tach (like a stack cluster) which you can program with any gauge as long as you have the sensors for them
http://www.stackltd.com/streetdash1.html
http://www.stackltd.com/st8916.html
Old Jan 15, 2009 | 08:02 AM
Driven's Avatar
i always stick them in the trunk.... [shrugs]
Old Jan 15, 2009 | 08:06 AM
yeah, a tight squeeze indeed. You need those PLX devices or something that has multiple gauges in one.
Old Jan 15, 2009 | 09:36 AM
papa5murf's Avatar
boost - useful
oil temp - useless
oil press - ehhh, useful but don't really need it
water temp - useless (that's what your temp gauge does for you)
exhuast temp - useful
air/fuel - useless
Old Jan 15, 2009 | 09:40 AM
dagle's Avatar
boost gauge - in my lap
EGT - in the trunk
water temp / AFR / ignition timing etc. etc. - laptop riding shotty
Old Jan 15, 2009 | 10:22 AM
S2KFTW's Avatar
I'm going to run an A pillar daul pod on my S with two AEM Serial gauges. two of those and you can see just about anything you want
Old Jan 15, 2009 | 10:26 AM
S2KFTW's Avatar
Originally Posted by papa5murf
air/fuel - useless
lol, you meant to type "essential" right?
Old Jan 15, 2009 | 10:47 AM
air/fuel - useless
unless it is a wideband.
Old Jan 15, 2009 | 10:54 AM
White Smoke's Avatar
i my honda
Global Mod
Don't need w/ a supercharger
Don't need
A must IMO
Don't need, already have one
Don't need if you get a WB
Also a must IMO, but if you can't afford it then get the EGT.
So really, you only need two gauges. You could have one serial gauge that displays everything, and all the sensors hooked up to an AEM EMS.
Old Jan 15, 2009 | 11:21 AM
98EK's Avatar
put this thread back on track...
Old Jan 15, 2009 | 11:23 AM
Boots's Avatar
^^^^no offense, but that looks cluttered as ****
Old Jan 15, 2009 | 11:24 AM
wtf?! it should not look like a plane cockpit when you get inside. that is horrible.
(and yes, i used the word 'cockpit') hahahaha
Old Jan 15, 2009 | 11:29 AM
Chris.'s Avatar
yea that setup looks terrible imo... i still think the best (even though its expensive as ****) would be to get the stack cluster, since it can put all the gauges into one screen
Old Jan 15, 2009 | 11:37 AM
ExVtec's Avatar
boost - useful
oil temp - useless
air/fuel - useless
Oil pressure/wideband
/thread.
Any top tuner will tell you these are the most important.
-Oil temp would be useful for a tracked car, a DD car not so much.
-Oil pressure is VERY important. What if a return leaks while you are tracking, or just DD, by the time the dummy light comes on, it's to late, goodbye motor.
-Water temp, again only useful for track days.
-Exhaust temp - meh...unless you want to monitor all 4 cylinders, otherwise it's not of much use.
-Wideband, as the regular narrowband a/f are only good for light shows.
I purchased a single gauge, the AEM serial piece that monitors everything, also allows me to set max/mins to monitor and will notify me if something is outside my predefined range, such as knock/oil pressure/etc. I'll leave it on wideband prolly. Ordered a single gauge pod from SOS for it. Should work out well me thinks.
Old Jan 15, 2009 | 12:46 PM
bigmacnfries's Avatar
sometimes it's nice just to have lots of pretty gauges and flashing lights
Old Jan 15, 2009 | 01:05 PM
Boots's Avatar
because i always look for the oppurtunity to give myself a siezure while im driving
Old Jan 15, 2009 | 01:13 PM
i don't see a gauge for the trim tabs and ailerons...
dagle's Avatar
when i get a headunit im probably gonna be mounting it where the stock radio controls are on the left side, block off the heater vent too and mount 2 gauges there. (will decide whats more important when the time comes) more likely than not the boost gauge will still be in my lap.
i was thinking of playing with the rearview mirror and mounting a gauge where the windscreen would be (behind the driver) but then the display would be backwards, perhaps with a custom convex(?) or concave lens that'll make images come out backwards some how.. lol
OR since we are allowed by law to run a GPS, use a 7" digital display monitor hooked up to a "carputer" in the trunk that will display it all. and if that's too technological to be accurate, mount the gauges in the trunk with it on a livefeed camera while the display tunes into the camera's view.
Old Jan 15, 2009 | 01:14 PM
^^ keen..
Old Jan 15, 2009 | 03:35 PM
CXHATCHver2.2's Avatar
Just take the audio mode push button out and put the serial gauge in there, I've seen it done a couple times and it looks nice if you do it right.
