SINGLE CAM BUILD!
Old Aug 5, 2006 | 08:41 AM
KMk51188's Avatar
Default SINGLE CAM BUILD!
ive made my choice im going to do a d series build but i got a D15B7 i got use that tranny but wat head n block should i use to get the best benfits
Old Aug 5, 2006 | 09:39 AM
aarontrini85's Avatar
Default Re: SINGLE CAM BUILD! (KMk51188)
using the tranny that comes with will be a waist if any thing save your self some cash on mods and just swap that trans to a y8 or z6 trans for now then look in to building the motor later
but when you do the motor i would go z6 head with a y8 intake mani and a b18b1 tb and port match it
that will make a decent mini me
Old Aug 5, 2006 | 09:50 AM
KMk51188's Avatar
so I already have money b I'm ready to do my build but what head and block should I use plus y can't I use my tranny is it bad? or shorter shifting or wat
Old Aug 5, 2006 | 09:52 AM
KMk51188's Avatar
sidekick bump
Old Aug 5, 2006 | 10:17 AM
DelSolDon's Avatar
the tranny you have now will give you better MPG, but not as fast accelerating as a Z6 or Y8 tranny.
Old Aug 5, 2006 | 11:27 AM
KMk51188's Avatar
Default Re: SINGLE CAM BUILD! (DelSolDon)
ooooo kk good lookin out everyone ne more ideas
Old Aug 5, 2006 | 01:19 PM
highendmike's Avatar
Multiple Accounts, banned multiple times
You might want to get in contact with Bisi he's your best bet on advice with the D-motor's.
Mike
Old Aug 5, 2006 | 01:56 PM
KMk51188's Avatar
Default Re: SINGLE CAM BUILD! (highendmike)
i contacted him for his help for this built thanks for the info
Old Aug 5, 2006 | 06:02 PM
Aquafina's Avatar
Longer gearing isn't always better for economy. I get 43 versus 38 mpg with my 4.7/EX trans instead of my stock Y7.
Use the B7. Put a cam in it and up the compression. SMSP headers rock D-soxors as well.
Old Aug 5, 2006 | 07:20 PM
baldheddave's Avatar
i sent you a IM KMK51188
Old Aug 6, 2006 | 08:27 AM
KMk51188's Avatar
Default Re: (baldheddave)
pmed
Old Aug 6, 2006 | 10:58 AM
KMk51188's Avatar
Default Re: (KMk51188)
can i use the same axels if i did a mini me
Old Aug 6, 2006 | 11:02 AM
Aquafina's Avatar
Yeah.
I use Advanced Auto axles in mine. Got them when I put my 5-lug (Y7 trans), still use them with my Y8 trans. Lifetime warranty.
Old Aug 6, 2006 | 01:11 PM
i have some tci axels thay work i had stock and made 190hp-170trq on a D16 a6 as long as you have good susp and preload the car at the track on the street you will be fine
Old Aug 6, 2006 | 06:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baldheddave &raquo;</TD></TR><TR><TD CLASS="quote">i have some tci axels thay work i had stock and made 190hp-170trq on a D16 a6 as long as you have good susp and preload the car at the track on the street you will be fine</TD></TR></TABLE>
holy **** is that on a n/a d??
Old Aug 6, 2006 | 06:47 PM
yes it is na i do have carbs for it now
Old Aug 6, 2006 | 07:07 PM
Aquafina's Avatar
170tq NA? put it on a chassis dyno
Old Aug 7, 2006 | 07:34 AM
jdm99integ__'s Avatar
you might want to go with a z6 head do a mini me swap
Old Aug 7, 2006 | 07:35 AM
z6 tranny
Old Aug 7, 2006 | 01:05 PM
Default Re: (Aquafina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">170tq NA? put it on a chassis dyno</TD></TR></TABLE>
i have seen boosted non vtec d series put down numbers like that but n/a is amazing
but your right it might have been a hub dyno
Old Aug 7, 2006 | 05:12 PM
it was on dyno jet---- not hub dyno the motor is bisi build
fastrxu
Southwest (Sales)
Jun 2, 2009 09:59 AM
stiffdogg06
May 11, 2007 08:56 AM
puertoroc7976
Sep 21, 2006 08:14 AM
URA91hatch
Oct 11, 2004 10:38 AM
ASHY-ELBOW
Nov 4, 2003 12:36 PM
