is there a way to link low & high beams together?
Old Aug 3, 2006 | 02:01 PM
bacardirico's Avatar
Default is there a way to link low & high beams together?
i was wondering if there's such a wiring mod to link low and high beams? what i mean is when i engage the hi beams on, i want the low beams to stay on as well. any instructions will be great. tx
Old Aug 3, 2006 | 02:05 PM
philosofy1's Avatar
Default Re: is there a way to link low & high beams together? (bacardirico)
why would you want to do that? on a civic, you won't notice anything since it's all one bulb.
Old Aug 3, 2006 | 02:08 PM
Mac2118's Avatar
I think he's talking about projectors that have different bulbs for both high and low
Old Aug 3, 2006 | 03:11 PM
CarbonizedDX's Avatar
Default Re: (Mac2118)
Get an auxiliary lights wiring kit from any auto parts store (make sure it's got a relay, just a switch and wiring). Wire up the kit as per the instructions (colors are different per kit) but connect the 12v power/supply line to the positive lead for the high beam (this is if your wiring harness uses two positives and one gound). Then simply mount the switch where you want and hazzah hi-low mod.......
Or if you are lil more adventurous you can get a Diode from radio shack and connect the high beams positive to the low beams positive with the white/silver band facing the low beam's power wire..... this allows power to flow from the high beam line to the low beam line and power both off the high beam power line, but when the low beams are on it keeps the highs isolated to it's own line. (again this is for a dual positive harness).
Old Aug 3, 2006 | 03:53 PM
VTECsound86's Avatar
Default Re: (CarbonizedDX)
hmm
Mr. Samurai
12
Oct 5, 2011 10:57 AM
rsdriver17
Lighting
Mar 5, 2008 11:03 AM
motorD16Y7
Lighting
Feb 11, 2008 12:13 PM
the all out kid
Lighting
Oct 11, 2007 06:35 PM
