engine dies after startup
i have a 94 vx with a b16a2 swap..the engines dies after startup and it has a hard time before starting up again...this usually happens when i refuel with an almost empty tank and also when i turn the engine off for a few minutes and try to start it up again...what seems to be the problem?pls. help!
Have you check the fuel pump to see if it's working well.......it might not be getting enough fuel to the engine to full cumbustion to start the engine. also check the fuel filter. or change it if you haven't changed it.
my homie said you might need a fuel pressure regulator.... check it out....that's all i can think of unless anybody else has any ideas?
hermtm2
23
Apr 8, 2009 06:17 PM
spyda man
Aug 21, 2007 09:31 AM
hair_rice
Jul 5, 2004 07:37 PM
