Droped EG= more body roll?
i know the shocks are still good. i know that slamming it does not give it any more performance thats not what i was looking for. does anyone know what spring rate comes with the Skunk 2 pro series coilovers? this is there full coilover setup
ya man, g2 pimp out that suspension w/ that super GSR for ur autocross racing, eh?
Blah, how much suspension do uneed for a daily driver?
IF ur running a GSR bottom and a B16 head u obviously aren't + ITR psitons, u obviously are keeping it NA, and obviously it's not a drag car...
So is it all neccessary for daily driving?
as for ur quesiton, I'd add the sway bars, usually u'll get better handlign w/ a lower car and less body roll (obviously), but if dropped too far it may need more stability b/c the structural integrity of ur suspension system is compromized by the height...sway bars obviously would fix this..
That or raise it up a bit...
Basically it's less body roll the lowr u go, but if u go too low u start to gain body roll unless u have sway bars...
That's my exp though....maybe not physics correct, but that's what I learned from my experience..
Just get the sway bars, guaranteed it'll feel right O.o
Also, b4 u get the sway bars, go to a tire shop and get a 4 wheel alignment (should be about 100 bux) - make sure all the tires are balacned properly, and all the caster/camber/toe is correct..
The lower u go the more u have to adjust ur camber (adjustable camber plates) - so it may be outta whack b/c of that...get that checked first...if it still feelsl ike it rolls to much, sway bars
blacktibby07
31
May 10, 2011 06:38 AM
HollywoodJack
Jun 13, 2010 03:11 PM
