weird acting headlights
Those combo switches get weak contacts after years of use. You can remove the steering wheel, then remove the combo switch, carefully take it apart, clean the contacts and stretch the tension spring a little, put it all back together and hope for the best. Or you can replace the combo switch for around $120.
Another strange problem that happens with the flip up head lights is that the wire harness, behind the head light, flexes and eventually the insulation on the harness cracks open letting bare wires short out. You can remove the head light and peel back the wire loom cover about 4-6 inches[to the bend] to check for that problem.
GearHeadDriver
Jan 20, 2016 06:31 AM
thecruzs2007@yahoo.com
Sep 12, 2009 11:02 PM
daredeezy619
Feb 7, 2008 04:27 AM
