Head light electrical problems.
I'm having problems with my head lights and blinkers. First of all, one of my headlights are dimmer than the other all tho i have checked the bulbs and bought new ones and they still do the same. And it seems my High beam indicator stays on and so does my left blinker (frozen on) when i turn on my headlights. Does anyone know how i can fix this? Not sure if its the switch where the turn signals are located or if its fuses.
HRD PKR
Re: Head light electrical problems. (daredeezy619)
Take your car in to a autozone and get your charging system tested.
Then if everything tested ok, Look into tested the wiring, switch.
Sounds like a broken ground wire in that system, check all the ground points in the engine bay and in the driver's kick panel area, making sure they are clean & tight. Other than a ground it could be a worn multi-function switch.
Bad connection for sure my hatch does it every once in awhile the highbeam light will light up a little and the drivers light will barly be on i open my hood move around my connection and walah it lights up! Need to get around to fix that once it's not flippin 20 degrees outside
Re: Head light electrical problems. (Civic9390)
thats exactly what's happening with mine. passenger light is dim instead it possibly might be a bad ground or something . ill get it tested and get back to you guys. thanks for the suggestions.
tchubs2K
03-27-2017 01:01 PM
ogawa_jiei
09-23-2006 06:10 PM
