should i use a 99 si brake master cylinder or get the correct one?
Old Aug 2, 2006 | 04:42 AM
infinkc's Avatar
Default should i use a 99 si brake master cylinder or get the correct one?
I have a 99 si brake master cylinder which has the brake lines on the opposite side of my 93 civic, should i go get the correct one for the 93 or should i just bend the brake lines to fit the 99 cylinder? i have the brake booster also since the mc is in a completely different posistion also mounting. Any downsides? car has no abs, came from the factory with rear disks.
Old Aug 2, 2006 | 08:12 AM
BlueIntegraBoy's Avatar
Default Re: should i use a 99 si brake master cylinder or get the correct one? (infinkc)
Are you looking for a larger MC? Get a 91 EX 15/16" MC. The brake lines are the same and bolts up to your stock booster. Plus it's larger than the 7/8" Si MC.
Old Aug 2, 2006 | 08:26 AM
infinkc's Avatar
Default Re: should i use a 99 si brake master cylinder or get the correct one? (BlueIntegraBoy)
i just want something that works, i dont care if its the stock one or not (my moms car) im just wondering if i should just go get the correct one or use the one i have and hope i can bend the lines.
Old Aug 2, 2006 | 08:27 AM
harley06's Avatar
whats the point of having a bigger brake master cylinder? and brake booster?? sorry im a noob
Old Aug 2, 2006 | 01:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infinkc &raquo;</TD></TR><TR><TD CLASS="quote">i just want something that works, i dont care if its the stock one or not (my moms car) im just wondering if i should just go get the correct one or use the one i have and hope i can bend the lines.</TD></TR></TABLE>
Go get a correct one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harley06 &raquo;</TD></TR><TR><TD CLASS="quote">whats the point of having a bigger brake master cylinder? and brake booster?? sorry im a noob</TD></TR></TABLE>
If you have larger brakes, you need more pressure.
Old Aug 2, 2006 | 01:59 PM
philosofy1's Avatar
if that's the case why are you even asking this question. common sense would be just get the exact replacement.
Old Aug 2, 2006 | 03:14 PM
infinkc's Avatar
Default Re: should i use a 99 si brake master cylinder or get the correct one? (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
if that's the case why are you even asking this question. common sense would be just get the exact replacement.</TD></TR></TABLE>
casue i have the si one already, if i can use the one i have why bother and buy a different one.
Old Aug 4, 2006 | 06:51 PM
infinkc's Avatar
Decided to use the 99 si one instead of buying the correct one, if anyone is wondering this is a picture of how i bent the brake lines going to the master cylinder, it wasnt a very hard thing to do at all.
mikeyz
Aug 2, 2006 03:37 PM
blulude92
May 26, 2006 10:03 PM
tomaseuro
Oct 17, 2005 02:05 PM
lollypopking
Jan 16, 2005 09:51 PM
Eggman
Oct 6, 2002 09:32 AM
