ctr cams on stock motor?
Old Aug 1, 2006 | 04:52 PM
jdmjeff's Avatar
Default ctr cams on stock motor?
i got a stock B16 right now and im looking to get a lil more power but i still want it JUST AS reliable as a stock B16... i was first thinking IHE then clutch flywheel and ctr cams. its still oem cams and the drivetrain will still be reliable... was also thinkin about a street tune w/ uberdata. what you guys think?
Old Aug 1, 2006 | 05:09 PM
C1CRX's Avatar
Traffic signal tech
sounds like cheap and reliable and maybe a little peppy lol
Old Aug 1, 2006 | 05:25 PM
jdmjeff's Avatar
Default Re: (lvcrx)
yeah thats what i was thinkin. would be under a grand and should pick up some midrange w/ the cams and topend w/ the header and exhaust plus perhaps better gas milage
Old Aug 1, 2006 | 05:41 PM
UncleD's Avatar
Default Re: (jdmjeff)
Do it! I wouldn't reccommend revving the type r cams past the stock rev limiter though with your stock valvetrain.
Old Aug 1, 2006 | 08:15 PM
Eg_TypeR's Avatar
Default Re: ctr cams on stock motor? (jdmjeff)
I wouldnt recomend switching to CTR cams unless u are planning on changing the valve springs also... U need Type R springs
Old Aug 1, 2006 | 08:22 PM
UncleD's Avatar
Default Re: ctr cams on stock motor? (Eg_TypeR)
Thats funny, I've installed MANY type r cams into stock B16's with fantastic results each time. Like I said above, stock rev limiter, you're cool.
Old Aug 1, 2006 | 08:43 PM
JSpin's Avatar
Default Re: ctr cams on stock motor? (clean rice)
i've put in two sets in stock b-series motors with no problems, but i probably wouldn't do so on the older b16's with single valve springs on one side.
Old Aug 2, 2006 | 06:37 AM
JDAMC's Avatar
Would you use itr retainers with itr valve springs? Or could you use the b16a one's?
(retainers)?
Old Aug 2, 2006 | 08:30 AM
Ass$nyper's Avatar
Pirate General...YARRRR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Do it! I wouldn't reccommend revving the type r cams past the stock rev limiter though with your stock valvetrain.</TD></TR></TABLE>
Very true, I take mine out to 8500 though because I don't care about it
I have another reason too but rather not remind myself of that
Old Aug 2, 2006 | 12:26 PM
Eg_TypeR's Avatar
Default Re: ctr cams on stock motor? (JSpin)
But wouldnt u want to atleast have the stock valvetrain for these cams, or ur saying u dont need em...... Honda just felt like putting them in for no apparent reason??
Anyways to the person who started the thread.... do it right!!! Dont do it the half *** way (Hacks!!), so at least this way u can have piece of mind, and u dont have to worry about hurting the motor.
Old Aug 2, 2006 | 12:47 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg_TypeR &raquo;</TD></TR><TR><TD CLASS="quote">But wouldnt u want to atleast have the stock valvetrain for these cams, or ur saying u dont need em...... Honda just felt like putting them in for no apparent reason??
Anyways to the person who started the thread.... do it right!!! Dont do it the half *** way (Hacks!!), so at least this way u can have piece of mind, and u dont have to worry about hurting the motor.</TD></TR></TABLE>The vavle train is made to hold the extra RPM CTRs will turn these arn't monster cams that need it.
If you don't turn extra high you'll be ok.
Old Aug 2, 2006 | 02:59 PM
jdmjeff's Avatar
Default Re: ctr cams on stock motor? (***-assin)
im thinkin the ONLY reason i would need a bigger valvetrain is when im reving past 8,200 (which i will not) i have a stock oem del sol w/ a obd1 b16 straight from the factory.
Old Aug 2, 2006 | 03:06 PM
allaboutdaz's Avatar
i was thinking about doing this in my 00 SI b16a2
any dynoes from before and after?
Old Aug 2, 2006 | 03:13 PM
Suck my DX's Avatar
like everyone said before...your fine with stock valvetrain if u retain ur factory rec limit
Old Aug 2, 2006 | 03:35 PM
jdmjeff's Avatar
Default Re: ctr cams on stock motor? (allaboutdaz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allaboutdaz &raquo;</TD></TR><TR><TD CLASS="quote">i was thinking about doing this in my 00 SI b16a2
any dynoes from before and after?</TD></TR></TABLE>
yeah that would be great. i think with my b16 tranny and a clutch flywheel and a good tune it should run very strong. not a big b16 fan but they are reliable as hell though
GEN2 LS
May 31, 2012 04:23 AM
richieTN
Mar 26, 2007 09:42 AM
jbell
Aug 1, 2004 09:50 AM
TwistedSI
Mar 21, 2003 12:16 AM
SiRex91
Nov 24, 2002 10:49 PM
