JDM EG6 cluster problem
Old Aug 1, 2006 | 04:24 PM
VTECsound86's Avatar
Default JDM EG6 cluster problem
So I got my jdm cluster in the mail today and the speedometer is messed up. The in at the bottom between 0 and 180 kph when I turn my car it gets stuck on the idle pin, has anyone every experienced this problem?is there anyway to fix?
Old Aug 1, 2006 | 04:33 PM
BlueIntegraBoy's Avatar
Default Re: JDM EG6 cluster problem (VTECsound86)
What??? The needle is stuck under the stop pin? If this is the case, the cluster must be been inverted a few times during shipping. To fix it, remove the cluster bezel and use your finger to rotate the speedo needle counter-clockwise to let it rest above the stop pin.
Old Aug 1, 2006 | 05:18 PM
Default Re: JDM EG6 cluster problem (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">What??? The needle is stuck under the stop pin? If this is the case, the cluster must be been inverted a few times during shipping. To fix it, remove the cluster bezel and use your finger to rotate the speedo needle counter-clockwise to let it rest above the stop pin.</TD></TR></TABLE>
ok I fixed the needle problem but now the high beam indicator doesn't work and I dont believe the amber lighting works, ******* ebay scammer
Old Aug 1, 2006 | 05:24 PM
Dude, calm down. When you buy a used cluster, most often than not, you'll have a few burnt bulbs. Replace the bulbs from your old cluster, make sure you remove the blue condoms. Replace the high beam indicator bulb with yours.
It will light up amber, as long as all your bulbs are working.
Old Aug 1, 2006 | 06:04 PM
CA6VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Dude, calm down. When you buy a used cluster, most often than not, you'll have a few burnt bulbs. Replace the bulbs from your old cluster, make sure you remove the blue condoms. Replace the high beam indicator bulb with yours.
It will light up amber, as long as all your bulbs are working.</TD></TR></TABLE>
<FONT COLOR="royalblue"> Yup.. The cluster itself is amber, not the bulbs. no need to freak. </FONT>
Old Aug 1, 2006 | 08:42 PM
Harryflores's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">You'll have a few burnt bulbs. Replace the bulbs from your old cluster, make sure you remove the blue condoms. Replace the high beam indicator bulb with yours.It will light up amber, as long as all your bulbs are working.</TD></TR></TABLE>
Holy **** this happend to me with my E-Brake bulb... change it and don't get that much stuff from e-gay!
American.Graffiti
11
Jul 4, 2006 04:25 PM
ronintegra
Jan 3, 2006 12:10 PM
itsJDMyo
15
Dec 30, 2004 09:47 PM
