overheating..... need help
Old Aug 1, 2006 | 07:22 AM
EK VTi's Avatar
Default overheating..... need help
Car is overheating when idel......just changed thermostat, refilled coolant, and it was fine for 2 days.... then overheat again when stop.....temp drop back down to normal when moving, then overheat when stop.....no white smoke coming out, any idea? Help please...... Also how do you know if you have a blown gasket?? Thanks in advance guys!!
Old Aug 1, 2006 | 07:27 AM
philosofy1's Avatar
Default Re: overheating..... need help (EK VTi)
if you had a blown gasket, the performance of the car would be really bad, not to mention you will see white smoke.
burb the system. the one thing people either forget or overlook.
let the car cool, open the radiator cap, start the car, pour more fluid into the radiator until you can't no more and then close the cap back up. and then you'll be all done, you shouldn't have a problem then!
Old Aug 1, 2006 | 07:32 AM
EK VTi's Avatar
Default Re: overheating..... need help (philosofy1)
Cool thanks!! I'll try that!!
Old Aug 1, 2006 | 03:10 PM
old man neri's Avatar
So it's only overheating when at a stop? I would check to make sure your cooling fan is engaging. I have a feeling it is not.
Cheers.
Old Aug 1, 2006 | 03:15 PM
sniggler316's Avatar
Default Re: (old man neri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">So it's only overheating when at a stop? I would check to make sure your cooling fan is engaging. I have a feeling it is not.
Cheers.</TD></TR></TABLE>
x2
Old Aug 1, 2006 | 06:56 PM
EK VTi's Avatar
Default Re: (sniggler316)
Yeah forgot to mention I did check the fan and it works fine, thanks for the inputs though ......any other ideas?
Depressionused
May 16, 2007 12:49 PM
Mr_Moos
Feb 13, 2006 05:59 PM
D C 5
Sep 16, 2005 11:00 AM
civais
Apr 11, 2005 02:47 PM
Todapwr
11
Dec 14, 2003 10:05 PM
