i need help prelude
i have an h23a1 honda prelude si 93 and it is over heating it is burning through water and coolent like there was none i have to place water and/or coolent about once or twice a week i have been checkin under the car for leak and there appears to be none i do not know what is worng with it can some on please help me on this also i would like to know what do u need to do a full swap to an h22 into my 93 prelude si and does it matter on if it is an h22a1 or h22a4 thank you for your time and please help me
flushing it won't help, the coolant HAS to be going somewhere, either leaking out of the radiator, heater hoses, engine, water pump, somewhere, OR if it's not leaking, and you are sure, it has to be going into your cylinders and out your tailpipe. Is it burning white smoke?
Get a top end gasket set (because you will need more than just a head gasket) from a local shop or ebay or something, and you will basically just have to remove the head and replace the head gasket and all the other stuff that comes with that job.
There is a lot to it though, and I don't think you should do it yourself. IMO you should take it to a shop, but if you want to attempt it yourself, order a helms manual from http://www.helminc.com , get all the tools you need and be carefull.
doesnt overheat all the time jus sometimes out of the blue maybe bout i would say once a week give or take a day or too it hasnt overheat in a while tho
