boost gauge problem i hope???
Old Jul 30, 2006 | 10:30 PM
DrivinVtec's Avatar
Default boost gauge problem i hope???
someone want to tell me why this say 15psi when im running a 7psi spring?
http://s21.photobucket.com/alb...2.flv
I can feel it stop maken power after it hits 7psi. bad gauge? got any ideas?Maybe kinked or crimped some how??
Old Jul 30, 2006 | 10:33 PM
komat's Avatar
Default Re: boost gauge problem i hope??? (DrivinVtec)
whats your setup?
Old Jul 30, 2006 | 10:38 PM
DrivinVtec's Avatar
Default Re: boost gauge problem i hope??? (komat)
stock motor for now. but for turbo:
herms fab log mani
turbonetics t3/t4oe 60 trim
38mm tial wg
open dp
450 injectors.
crome tunnin
thats the gist of it.
Old Jul 30, 2006 | 11:02 PM
DrivinVtec's Avatar
anyone?
Old Jul 30, 2006 | 11:34 PM
DrivinVtec's Avatar
i sprayed some wd40 in the WG an Bov. I think the BOv is also sticking. but i took it for a quick drive. i couldnt get up on but it seems okay. maybe because of the opem Wg an the heat shield i have right in front of it causen it to stick.anyone heard of this before?
Old Jul 30, 2006 | 11:54 PM
DrivinVtec's Avatar
well i went an looked at the whole setup. i think maybe my WG is sticking because i dont have a pipe an i have a heat shield about 2-3inchs from it. so when it open up it doesnt have a good place to vent causen it get some type of carbon build of. em i fetching here?
i sprayed some wd40 in it along with the BOV. I can accully her the bov now..i couldnt before. so i took it some more. 5k it was a 10 psi. nowi think thats about right considering the open dp. but it sure didnt get to 15psi. but it is about 40 degrees colder. would that play a factor. i would think it would be more boost if it was colder. i dont know.
Old Jul 31, 2006 | 12:10 PM
DrivinVtec's Avatar
up
Old Jul 31, 2006 | 02:45 PM
95jeremie's Avatar
Default Re: (DrivinVtec)
don't know but i'll bump
i am in mid build and would like to know
Old Jul 31, 2006 | 07:02 PM
DrivinVtec's Avatar
Default Re: (95jeremie)
FIXED!!!!YESSSSS...
Well i went to fo look at the wg flange an make sure i had the right bolts. well moved the vac hose connected to the turbo to the wg..well this is what i found :eek
easy fix took it for a spin..7psi no prob.
Old Jul 31, 2006 | 07:09 PM
95jeremie's Avatar
Old Jul 31, 2006 | 07:15 PM
DrivinVtec's Avatar
thanks..im just surpised the motor held 15psi a few times..crazy.
Jeffrey9
Sep 19, 2008 06:23 AM
hondamonkey
Aug 6, 2007 07:02 PM
esedulerp5tenin
May 21, 2007 02:56 PM
eg6T
Oct 1, 2004 06:14 PM
paulzy
Dec 23, 2001 05:47 PM
