JGS 44mm Billet Wastegate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nebulight »</TD></TR><TR><TD CLASS="quote">At that price, I would just stick with a Tial 44mm, btw, what's your VW setup like?</TD></TR></TABLE>
boost factory custom tubular mani, gt35R .82 v-band exhaust housing, 630cc injectors for right now on revo software, will be getting a custom tune later down the road. 3" Dp and catback. built bottem end... just the basics. looking for 600whp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quickgti1.8t »</TD></TR><TR><TD CLASS="quote">
boost factory custom tubular mani, gt35R .82 v-band exhaust housing, 630cc injectors for right now on revo software, will be getting a custom tune later down the road. 3" Dp and catback. built bottem end... just the basics. looking for 600whp</TD></TR></TABLE>
wow, that's a huge hotside for a 1.8t, should look into solid lifters for the head, or at least some cams and/or springs to get some more revs. You should really ditch the stock ECU too, look into that 034 that all the id=27 junkies are blowing their loads over, or a haltec. I don't know how well the 630cc injectors are going to do with 600whp.
i ran a gt35R .63 a while ago and had full boost at 4700rpm and reved to 7700rpm on completely stock motor lol.... I will stick with the stock ECU and have someone tune it... 630cc injectors will be good upto 25psi on this turbo i believe..... But i will need 1000cc for 600 whp
</TD></TR></TABLE>i ran a gt35R .63 a while ago and had full boost at 4700rpm and reved to 7700rpm on completely stock motor lol.... I will stick with the stock ECU and have someone tune it... 630cc injectors will be good upto 25psi on this turbo i believe..... But i will need 1000cc for 600 whp
i ran a gt35R .63 a while ago and had full boost at 4700rpm and reved to 7700rpm on completely stock motor lol.... I will stick with the stock ECU and have someone tune it... 630cc injectors will be good upto 25psi on this turbo i believe..... But i will need 1000cc for 600 whp</TD></TR></TABLE>
Then you are going to need a driver box or some type of stand alone fuel system. If you are on the east coast, you should drive to CT and have Tony Chick tune it.
Then you are going to need a driver box or some type of stand alone fuel system. If you are on the east coast, you should drive to CT and have Tony Chick tune it.</TD></TR></TABLE>
Im only 3000 miles away lol, I was going to have him tune it. But i decided to go 034-efi, the 2 step and anti-lag won me over lol... Plus i can run 1600cc injectors
turboedc2
May 20, 2005 12:57 PM
