Questions About Piecing together my turbo kit
I finaaly took everyones advice and I am not going to buy anything form ebay. I am deciding on whether I should build my block or not now. I want to know I want at least 200 to 250 hp on 8psi. And if I could run that with my stock internals. I know you guys runinto this question alot but I realy do need a positive answer on whether to do it or not.
what kind of condition is your motor in now? compression numbers and a leak down will give you the best idea. If everything checks out, instead of building your block, take that money and have it tuned to the power goals you want by one of the professional tuners from HT.
You can find the list of tuners in the sticky thread at the top in this forum.
thats my exact goal too..but when i found out that #4 was low..it made me not want to boost my car but since i already had everything i'm throwing it in anyways..and run low boost and see how it goes from there i'll keep you updated..and my gsr block has 175,000 on her
92accordEX4life
Aug 9, 2008 06:47 PM
