98 itr turbo question
Old Jul 29, 2006 | 04:55 PM
filipevti's Avatar
Default 98 itr turbo question
hi there, im thinking seriously in turbocharge my 98 itr but i want a daily driven car i will post the setup that im wondering to buy, please correct-me if wrong ou forgot something
-turbo (i dont know what kind of turbo to buy i just want to run 5psi)what do you guys advise me to buy)
-rev hard manifold
-precision intercooler
-rc 550cc
-arp head studs
-cometic headgasket
- and tune
Old Jul 29, 2006 | 05:57 PM
SiR99's Avatar
Default Re: 98 itr turbo question (filipevti)
downpipe
walbro fuel pump
chipped ecu
obd1 converion harness
blow off valve
chargepipes
wastegate, if its not internal
oil lines for turbo
im not sure if its absolutely necessary, but you have to modify your factory fan or get a slimmer fan to make space for everything
Old Jul 29, 2006 | 07:35 PM
evade this honda's Avatar
Default Re: 98 itr turbo question (SiR99)
what about compression issues Isnt 11:1 I would have turboed my delsol a long time ago if it wasnt for the ctr pistons
Old Jul 30, 2006 | 12:59 AM
Speed Infliction's Avatar
Default Re: 98 itr turbo question (evade this honda)
you can boost 5 psi on 11:1, but i wouldnt go any higher unless you have a great tuner
Old Jul 30, 2006 | 01:37 AM
MiraiZ's Avatar
If thats all you're planning to invest in your turbo setup, then save your money and stay NA, 'cause your car will not last a week...
Old Jul 30, 2006 | 06:14 AM
filipevti's Avatar
thank u all guy, about the compression issue the cometic headgasket is 3mm does this solve the higher compression issue ????
Old Jul 30, 2006 | 09:20 AM
Default Re: 98 itr turbo question (MiraiZ)
what would you recommend then....? im not sure what your sayin
Old Jul 30, 2006 | 10:44 AM
filipevti's Avatar
i think that the 3mm headgasket lower the compression thank you all for helping me
Old Jul 30, 2006 | 11:08 AM
b00sted_hatch's Avatar
Little Hercules
Default Re: (filipevti)
you have a stock 10.6:1 CR. you'll be just fine boosting 5psi. you'll probably make around 230-250whp on that setup.
make sure the turbo isnt to big. a t3/t04e turbo would be almost perfect for you car. i love it!
Old Jul 30, 2006 | 11:12 AM
filipevti's Avatar
but with a t3-t4e isnt big i was think to put a t3 because the spool time
Old Jul 30, 2006 | 11:40 AM
93CX's Avatar
I'm boosting 8psi on CTR pistons no issues
Old Jul 30, 2006 | 11:47 AM
tegasaurus's Avatar
get a gt28 turbo, boost 6 psi. Have it tuned conservatively. Do everything to keep underhood temps down and you'll have a blast.
St00pid tuned a b18c5 on 6 psi. Made nice power on a conservative tune. don't be discouraged from the project, just know what you're getting into.
Old Jul 30, 2006 | 11:49 AM
filipevti's Avatar
thank u all, my whp objectives is 215whp do you think that with proper tuning and this setup i can archieve this??
Old Jul 30, 2006 | 11:54 AM
SiR99's Avatar
ya you can get 215whp easily, but you have to get the things i listed. Your limit for the stock motor is around 300whp, so if you tune it good, you should last pretty long on only 215whp
Old Jul 30, 2006 | 12:31 PM
TURBO4drTypeR's Avatar
there's a member on here that made 380+whp on a stock 98+itr with JUN3 cams on pumpgas(93)@14psi or so
Old Jul 30, 2006 | 12:45 PM
filipevti's Avatar
380+ on pump gas damm, once more thank u
Old Jul 30, 2006 | 12:57 PM
Little Hercules
oh and dont forget a good clutch
id run 7psi if i were you. because 215whp jsut wont satisfy you at all
just my .02
Old Jul 30, 2006 | 01:07 PM
dont forget PSI DOES NOT MAKE POWER!!!
its the CFM of the turbo you have(size of turbo)
Old Jul 30, 2006 | 03:45 PM
filipevti's Avatar
yes but what turbo does you recomend (t3/t4,just t3, gt28rs)i want that the turbo hit at 3500rpm+-
Old Jul 30, 2006 | 04:29 PM
spoolin turbo s's Avatar
t3 super 60, gt28r, or gt28rs
depending on how much headroom you want to leave for the future and how much money you want to spend
if i was going to go the t3 route i'd say might as well do the super 60 because the difference in it and a .63 t3 would be very small
Old Jul 30, 2006 | 10:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filipevti &raquo;</TD></TR><TR><TD CLASS="quote">yes but what turbo does you recomend (t3/t4,just t3, gt28rs)i want that the turbo hit at 3500rpm+-</TD></TR></TABLE> if you're not limited to funds get a gt35r... if you're on a budget get an sc61... that way you can make the power you want for what you have and have plenty more to play with...
that gt28rs is what was used on that JDM ITR and those things max out around 400ish give or take... but responds great with ITR motors
Old Jul 30, 2006 | 10:38 PM
quicksilver1689's Avatar
i ♥ snails
215whp haha just stick with n/a then. itr's have been bosted reliable many times its proven just watch the for detonation and keep an eye on the timing. gt28 would be my choice if i had ur setup good response and enough flow too keep u happy in the future.
Old Aug 3, 2006 | 01:31 PM
filipevti's Avatar
thaks all u guys for helping me
Old Aug 3, 2006 | 02:30 PM
Little Hercules
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filipevti &raquo;</TD></TR><TR><TD CLASS="quote">thaks all u guys for helping me </TD></TR></TABLE>
no problem man
thats what we people on honda-tech do. help people if they need help
Good luck on your project mang
Old Aug 3, 2006 | 02:35 PM
sirguy01's Avatar
Default Re: (b00sted_hatch)
i dont suggest playing with timing that much on a set up like that. I'm over 400whp and haven't touched my timing at all.
Just get it tuned properly with the fuel and all you should be good.
buddy of mine has a 01 R, evo2 exhaust, no cat, drag kit, pumped out 244whp @ 6psi on a shitty tune.
you should make your 215 easy...
ylfotevoli
Oct 4, 2007 07:36 PM
CroteTurbo
Aug 23, 2005 08:17 AM
tr123gone
Jun 20, 2005 12:28 PM
fierce
Jan 17, 2002 03:25 PM
