DOHC VTEC Del Sol 1100 to good to be true?
Old Jul 29, 2006 | 03:54 PM
LerRoy1119's Avatar
Default DOHC VTEC Del Sol 1100 to good to be true?
I found a Del Sol for a 1100 with a bad clutch master cylinder. Everything else on the car seems fine no major body damage, nothing missing and all stock.The guy says the car wont start or shift because of the bad clutch master cylinder, but he assures me that the motor is fine. Any comments or opinion would be of great help. Thnx.
Old Jul 29, 2006 | 04:00 PM
mugenpowered's Avatar
Default Re: DOHC VTEC Del Sol 1100 to good to be true? (LerRoy1119)
sounds too good to be true. atleast compression test the engine and have a mechanic look it over.
Old Jul 29, 2006 | 04:01 PM
WhiteOnRice's Avatar
I was going to buy a Del Sol CHASSIS for $1200. I'd go for it after a history report.
Old Jul 29, 2006 | 04:02 PM
MassScene's Avatar
Default Re: DOHC VTEC Del Sol 1100 to good to be true? (fizix_skate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fizix_skate &raquo;</TD></TR><TR><TD CLASS="quote">I was going to buy a Del Sol CHASSIS for $1200. I'd go for it after a history report.</TD></TR></TABLE> even if the motor was blown. you would still probably have the head, the tranny, basically everything for a swap besides the blown part
Old Jul 29, 2006 | 05:21 PM
LerRoy1119's Avatar
Default Re: DOHC VTEC Del Sol 1100 to good to be true? (MassScene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MassScene &raquo;</TD></TR><TR><TD CLASS="quote"> even if the motor was blown. you would still probably have the head, the tranny, basically everything for a swap besides the blown part</TD></TR></TABLE>
Yeah thats what i was thinking of
Modified by LerRoy1119 at 7:42 PM 7/29/2006
Old Jul 29, 2006 | 05:34 PM
dewoine's Avatar
this could be true .depends on who your buying it from some people don't know the value of a certain car. i came across alot of cars that where sitting in the back yard collecting tree sap
Old Jul 29, 2006 | 06:45 PM
LerRoy1119's Avatar
Default Re: DOHC VTEC Del Sol 1100 to good to be true? (dewoine)
I just thought of something shouldn't you be able to start even if the clutch master cylinder was bad. I think as long as the clutch is pressed the car should start.
Old Jul 29, 2006 | 06:51 PM
Paprika's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LerRoy1119 &raquo;</TD></TR><TR><TD CLASS="quote">I just thought of something shouldn't you be able to start even if the clutch master cylinder was bad. I think as long as the clutch is pressed the car should start. </TD></TR></TABLE>
But if the clutch master cylinder isn't working.. the clutch can't be disengaged... thus you can't start the engine.... unless you start it in neutral ??
Old Jul 29, 2006 | 06:56 PM
BauleyCivic's Avatar
Risky Business
Default Re: DOHC VTEC Del Sol 1100 to good to be true? (Paprika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paprika &raquo;</TD></TR><TR><TD CLASS="quote">But if the clutch master cylinder isn't working.. the clutch can't be disengaged... thus you can't start the engine.... unless you start it in neutral ??</TD></TR></TABLE>
The switch is on the pedal, not in the clutch. If the transmission is in neutral and the clutch pedal is pressed in the car should start fine.
Old Jul 29, 2006 | 07:30 PM
Paprika's Avatar
Default Re: DOHC VTEC Del Sol 1100 to good to be true? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">
The switch is on the pedal, not in the clutch. If the transmission is in neutral and the clutch pedal is pressed in the car should start fine.</TD></TR></TABLE>
Right...
I've never driven a manual so I don't know..
Old Jul 29, 2006 | 08:03 PM
H2290's Avatar
Agreed, it is just an electrical switch on the pedal itself. If it won't start in neutral with the pedal pressed down and the guy says it is because of the cylinder he is full of crap and I wouldn't buy a thing from him.
Old Jul 29, 2006 | 08:55 PM
Syndacate's Avatar
Well ****, anything's possible, I saw a 9 second eclipse on sale for ebay for like 3k w/ lambo doors, body kit, the works
his son got killed in iraq and he couldn't bare to look at the car...so ****, anything's possible
I've seen tons of cheap deals when pple need to move or need the $ fast, it's surprising, I rather sit around and wait for deals like those to pop up then to shop...that's what I'm doing now...waiting for the right deal on a honda engine, somebody'll get desperate and want to sell something, I know it, it's a matter of deductive logic... Most pple have financial issues at one point or another...(or all)
though like they said, it wouldn't "not" start b/c of a broken MC, the switch'd still be pressed down when u step on the clutch...
see if it's something else...but even if it's something more, a del sol for 1100 is still worth it, just do a carfax to see if it was totalled recently or something like that...fire or something...'cause even just for a shell that's nice, even if u have to swap in a new engine that's nice, y'kno?
zxzDarkCloudzxz
Jul 26, 2016 01:57 PM
s2kds
14
Jan 23, 2004 02:58 PM
Spool Me Up
Sep 13, 2003 03:53 PM
Soon_2b_evil
19
Jun 29, 2003 01:52 PM
youngwon22
Jun 6, 2003 07:39 PM
