code 5; MAP sensor??
Old Jul 29, 2006 | 09:04 AM
.BigSexy's Avatar
most hood white kid
Default code 5; MAP sensor??
Ok, so I just finished my swap, JDM h22 into my 4th gen. I am running a chipped p28 ecu. I am throwing a code 5, which is the MAP sensor. Now to my knowledge, when swapping in an h22, and going from the f22, you didn't have to connect the MAP sensor on the TB, since there was one already one on the firewall. I do not have my vacum line hooked to the MAP, would this cause me to throw that code. The car is idling like ****, but I dont have my header bolted to the B-pipe, b/c of the difference of flanges, and I only have 1 bolt in the header/downpipe...
so I know its gonna sound like **** b/c of that...
help me!
Old Jul 29, 2006 | 09:42 AM
.BigSexy's Avatar
most hood white kid
Default Re: code 5; MAP sensor?? (egcoupe94)
This is a video of the problem in real time
http://www.youtube.com/v/W0LjyURcjjk
Old Jul 29, 2006 | 09:45 AM
.BigSexy's Avatar
most hood white kid
picture of vacum line thats creating all the havoc!!
Old Jul 29, 2006 | 09:52 AM
ShinobiLude's Avatar
Cory,
The map sensor on the firewall has got to have a vacuum or it cant get a proper reading. Without the vacuum its just the same as it not being connected at all. The map sensor vacuum on the f22 intake manifold is on the throttle body I believe. If you have a throttle body that has the map sensor on top of it of course that connection wouldnt be there. Take one of the blocker plugs off your extra vacuum connections on the intake mani itself and hook up the map sensor on the firewall to that. It should eliminate this issue.
For the love of God get that other bolt. You have been talkin so much shyt to me cause you got your swap done first. HA!!!!!
Old Jul 29, 2006 | 09:57 AM
.BigSexy's Avatar
most hood white kid
Default Re: code 5; MAP sensor?? (ShinobiLude)
what bolt are you talking about? I just drove it, and no CEL!! But still idles like ****. It wont hold idle, you have to rev it like crap, im going to make another video...be back in a minute.
Old Jul 29, 2006 | 10:09 AM
I'm talking about your header. Get that fixed please.
You just said that you threw a code 5 correct? You didnt do anything to the car and now its NOT throwing a code?
Old Jul 29, 2006 | 10:10 AM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShinobiLude &raquo;</TD></TR><TR><TD CLASS="quote">I'm talking about your header. Get that fixed please.
You just said that you threw a code 5 correct? You didnt do anything to the car and now its NOT throwing a code? </TD></TR></TABLE>
correct, yes, I need to get the exhaust fixxed, going to do that monday. I was throwing a code 5, now im NOT throwing it, and I did noithing to correct it. Im uploading my video right now, be up in about 10 minutes.
Old Jul 29, 2006 | 10:18 AM
john d
Guest
Posts: n/a
i got a mapsensor for sale if thats the problem
Old Jul 29, 2006 | 10:21 AM
.BigSexy's Avatar
most hood white kid
Default Re: code 5; MAP sensor?? (john d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d &raquo;</TD></TR><TR><TD CLASS="quote">
i got a mapsensor for sale if thats the problem</TD></TR></TABLE>
ill let you know. but I really have no clue right now. Im tempted to park it, and just wait for my dad to fly in from tx to fix it.
this is a big *** video
Old Jul 29, 2006 | 11:24 AM
.BigSexy's Avatar
most hood white kid
http://www.youtube.com/watch?v=sT0uW7AhKd0
new video!!
NASCAR FTW!! But let me know what ya'll think
Old Jul 29, 2006 | 11:30 AM
soundbomber's Avatar
haha that intro had me dyin' lol
Old Jul 29, 2006 | 11:52 AM
.BigSexy's Avatar
most hood white kid
Default Re: code 5; MAP sensor?? (soundbomber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">haha that intro had me dyin' lol</TD></TR></TABLE>
glad you liked it..any insight on my problem?
Old Jul 29, 2006 | 11:56 AM
so you're using the f22 throttle body and foregoing the map sensor on the firewall?
Old Jul 29, 2006 | 12:06 PM
90civichb's Avatar
am i understanding it correctly when I assume that you are not running a map sensor? or are you running a map sensor and still have a second vacuum line that is open? plug it and look elsewhere if that is the case...
If you ARE running no map, just slide the map on to the end of the open line and plug it up, it should still work fine. That is how we did it on the jdm b16 that was installed in a local guys car.
Old Jul 29, 2006 | 12:08 PM
90civichb's Avatar
Default Re: code 5; MAP sensor?? (90civichb)
nm i don't know **** about h22s.. edited this post....
why don't you have the vaccum line running to the hole in the TB directly in place of the map sesnor, that seems to be the solution without knowing crap about an h22.. how else would the MAP on the fire wall be able to read vacuum?
Old Jul 29, 2006 | 12:25 PM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">so you're using the f22 throttle body and foregoing the map sensor on the firewall?</TD></TR></TABLE>
nope...that is the h22 TB, but I believe it is a 5th gen. IM
Old Jul 29, 2006 | 12:27 PM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichb &raquo;</TD></TR><TR><TD CLASS="quote">am i understanding it correctly when I assume that you are not running a map sensor? or are you running a map sensor and still have a second vacuum line that is open? plug it and look elsewhere if that is the case...
If you ARE running no map, just slide the map on to the end of the open line and plug it up, it should still work fine. That is how we did it on the jdm b16 that was installed in a local guys car.</TD></TR></TABLE>
I am running a MAP sensor, it is just throwing a code. The MAP on the 4th gens is on the firewall, so there is no plug on the harness for the one on the TB. i was told just to leave it there to hold vaccumm...i never unplugged the one on the firewall, just the hoses, but having trouble figuring out where to send them
Old Jul 29, 2006 | 12:29 PM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichb &raquo;</TD></TR><TR><TD CLASS="quote">nm i don't know **** about h22s.. edited this post....
why don't you have the vaccum line running to the hole in the TB directly in place of the map sesnor, that seems to be the solution without knowing crap about an h22.. how else would the MAP on the fire wall be able to read vacuum?</TD></TR></TABLE>
the hoses leading from the MAP to the TB, let me find a pic of my old engine bay before i swapped...
Old Jul 29, 2006 | 12:42 PM
.BigSexy's Avatar
most hood white kid
ok...so I cant find a pic of my old engine bay that I have hosted. anyone have a pic?
Old Jul 29, 2006 | 01:49 PM
.BigSexy's Avatar
most hood white kid
ok...so I just looked at a schematic of the vaccum source, and its showing that the big nipple on the throttle body goes to the EVAP canister? and there are 2 nipples on the rear of the IM, that those go to my MAP? or can I just unplug the MAP from the firewall, adn plug it up on the one on the TB? I know I would have to lengthen wires for this.
Old Jul 29, 2006 | 11:14 PM
.BigSexy's Avatar
most hood white kid
still having my problem...
Old Jul 30, 2006 | 01:10 PM
92hondalude's Avatar
i took a pic and hosted it for you.
hope this helps if you need anymore help let me know.
yes i am a white man
yes you need to send me $20 to my paypal.
Old Jul 30, 2006 | 01:17 PM
Default Re: code 5; MAP sensor?? (92hondalude)
the first video you had the vacumes all fucked up
i dont think you have the right TB
it looks like you got the 5th gen tb witch has the map sensor on the top of the tb.
try unpluging your old one and plug it on the one on top of your tb.
Old Jul 30, 2006 | 03:20 PM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude &raquo;</TD></TR><TR><TD CLASS="quote">the first video you had the vacumes all fucked up
try unpluging your old one and plug it on the one on top of your tb.</TD></TR></TABLE>
i have to lengthen the wires. I found out today I had a vacum leak which wouldnt let it idle right. swapped ecu's for a JDM p13, and idles good now, still gotta fix that MAP. going to do that tonight
Old Jul 30, 2006 | 05:08 PM
gooseman's Avatar
unplug it from the firewall and plug it into the MAP on the TB
FSS13foxtrot
Jan 20, 2008 06:23 AM
92ehatch
16
Feb 19, 2007 11:41 PM
Sci_v_icI
Apr 5, 2006 10:44 AM
barry11j
Aug 4, 2004 09:45 AM
sakums20
Apr 29, 2004 02:40 PM
