How do I know if I have ABS????????
Old Jul 27, 2006 | 03:17 PM
churbor's Avatar
Default How do I know if I have ABS????????
so i have a 93 civic ex and I dont know if it has abs brakes or not and I need to figure out how to tell.
I know mine has a slightly larger rotor and the caliper has two bolts instead of one with the rod that it pivots on.
please help me I need to know ASAP
thanks
Old Jul 27, 2006 | 03:26 PM
philosofy1's Avatar
Default Re: How do I know if I have ABS???????? (churbor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by churbor &raquo;</TD></TR><TR><TD CLASS="quote">so i have a 93 civic ex and I dont know if it has abs brakes or not and I need to figure out how to tell.
thanks</TD></TR></TABLE>
you caliper is suppose to have 2 bolts. i really don't understand what you mean by rod and pivoting.
your 93 ex doesn't have abs, but there's a couple ways you can tell.
1. when you start up your car on the dash a abs light should light up.
2. abs civic's came with rear disc brakes, i believe you have drums at the rear.
hope this helps!
Old Jul 27, 2006 | 03:30 PM
-Gambit-'s Avatar
i say just go down an empty road and slam on the brakes. If they lock up then you dont have abs
Old Jul 27, 2006 | 03:31 PM
G2 Speed's Avatar
Default Re: How do I know if I have ABS???????? (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">you caliper is suppose to have 2 bolts. i really don't understand what you mean by rod and pivoting.
hope this helps!</TD></TR></TABLE>
Not ture y0!, I have abs.. drums ftw
Look for an Abs light, or abs sensor... should be as easy as that...
https://honda-tech.com/zerothread?id=1584925
Old Jul 27, 2006 | 03:36 PM
philosofy1's Avatar
Default Re: How do I know if I have ABS???????? (G2 Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed &raquo;</TD></TR><TR><TD CLASS="quote">
WOW! do you really? that's kind of cool, i've never seen that on the hondas. i have seen that on some gm cars. good to know.
Old Jul 27, 2006 | 03:41 PM
ACURAPOWERED's Avatar
double tap!?
Old Jul 27, 2006 | 03:47 PM
pennies_hatchie's Avatar
Default Re: (ACURAPOWERED)
just pop open your hood, look to the left and you should see the abs unit right after the headlight, next to the intake, (do you see the orange plug and metal lines). if there's nothing there, then you dont have abs
different car, same idea
Modified by pennies_hatchie at 7:15 PM 7/27/2006
Old Jul 27, 2006 | 04:05 PM
krazyhmongboi's Avatar
^^what are we looking for again...haha my eyes got lost looking at the car again..
Old Jul 27, 2006 | 05:30 PM
tpr's Avatar
tpr
Remove the wheel, look on the inside of the hub at the cv axle where it goes into the hub. There will be a tone wheel pressed onto the cv axle. Looks kind of like a timing gear only lots more and shorter teeth. There will also be a wire to the magnetic pickup arranged over that same tone wheel. It will also have more than just a master cylinder and proportioning valve. There will be an aluminum block (somewhere in the engine bay)with lots of hydraulic pipes and fittings along with an electrical harness connected. It should also run a test of the ABS warning light in the speedo display when you turn on the ignition. No ABS light no ABS.
Old Jul 27, 2006 | 05:34 PM
Syndacate's Avatar
lmao
these answers are funny
pple examining the engine bay, or taking off the wheel
2 ways, REALLY easy, easeist by FAR
do 30 mph, drop ur brake to the floor, if u hear a springing noise and ur brakes don't lock, u have ABS, if htey lock, you don't have it...
2, there's a light on ur dashboard, u don't even need to start the car, shine a flashline at ur cluster and u'll be able to see all teh dummy lights there and what they all see, if there's none that say ABS, u don't have ABS, there'll just be a blank black cover over one of 'em
edit:
"you caliper is suppose to have 2 bolts. i really don't understand what you mean by rod and pivoting.
hope this helps!"
Naw, ABS was optional on the EX from 93-95, they always came with drums in the rear...
Old Jul 27, 2006 | 05:53 PM
crazy sohc vtec guy's Avatar
Default Re: (pennies_hatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie &raquo;</TD></TR><TR><TD CLASS="quote">just pop open your hood, look to the left and you should see the abs unit right after the headlight, next to the intake, (do you see the orange plug and metal lines). if there's nothing there, then you dont have abs
Modified by pennies_hatchie at 7:15 PM 7/27/2006</TD></TR></TABLE> wow hell of clean
Cschwind777
Jul 28, 2007 11:00 AM
y2kferari
Feb 1, 2007 06:12 PM
2DoorBandit
Jan 5, 2007 06:11 PM
eg8civic93
May 8, 2006 08:22 AM
klovewell
May 2, 2004 11:23 AM
