Turbo build how much power will i be making aprox. guess
i have a b18c block godzilla sleeves and arias 9:1 comp and eagles h-beam rods and REV valves and dual valves springs and retainer and type r camshafts, edelbrock i.m. aem fuel rail areomotive fpr, eriks racing tb
Turbo setup: gt35r with a top mount manifold tial 50mm bov 44mm wg precision intercooler 750hp 1000cc precision injectors greddy boost controller 4"dp and 3"ic piping all tuned with hondata s300
i wanna make around 600 hp i was wondering if i could reach my goal with this setup i havent put the turbo kit on i was wanting some feedback on approx how much boost i can run i wanna push 25 thank you
do you think the eagle rods will be able to handle it or do i need to switch of some different ones like pauter
as long as the bolts are 3/8 on the rods youll be ok.
as for the boost, i think closer to 30 will be the ticket.
similar setup to mine w/o the top mount though and i netted 540 so far at 28 psi, but on a tired very tired old b16.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lonnieboosted »</TD></TR><TR><TD CLASS="quote">600 is possible with your setup, but why that number though?</TD></TR></TABLE>
Cause thats prob his power goal, im going for 650+ right now on an 81.5mm bore.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T »</TD></TR><TR><TD CLASS="quote">
Cause thats prob his power goal, im going for 650+ right now on an 81.5mm bore.</TD></TR></TABLE>
As a street car? Or track car? because 400 is really useless on the street
Well 450-500 on pump w/ alky injection, its a real street GSR currently running an LS Trans, full interior and no cage as of yet..... I got a LSD and I am about to install an AVC-R for gear based boost, gonna see what happens.
good luck with the avc-r ben. no sarcasm, just that i havent been able to get it to work that well on a few cars. well not me personally, but a few people i know have had little or no good luck with that controller.
As a street car? Or track car? because 400 is really useless on the street</TD></TR></TABLE>
useless? yes, fun? explitive yeah. my car is 540 whp, and see's the street when the axles arent broken. actually it is closer to 400+- on pump.
Yea I hear mixed responces on the AVC-R, its got to be better than just running 20lb in all 5 gears
I tend to learn the hard way so thats probably a sign of things to come.... including axles.
600 is just my goal where i wanna have the motor i wanna hope to run at least high 10's its gonna be a mainly track car. will race fuel make a bigger difference boostedcivicsir what ems are you running and wat axles should i go with what some good brands?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm inc »</TD></TR><TR><TD CLASS="quote">600 is just my goal where i wanna have the motor i wanna hope to run at least high 10's its gonna be a mainly track car. will race fuel make a bigger difference boostedcivicsir what ems are you running and wat axles should i go with what some good brands?</TD></TR></TABLE>
Well, you not gonna make 600 on pump gas.So yes race gas makes a big difference
you will need c16, we got about 400whp on pump on my car.
i did 540 on gsr cams, i have maz worx v1 turbo cams ready to go in, i have broken a gator stage 3 mod, and end of the season i will be goin with dss stage 5's. you dont need 600 whp to go 10's. low 5's with a good setup, and youll be fine. i went 10.96 with 520 and 2650 lb w/driver car weight. yes i am a fat ***.
600 should be very easy on that set up! eagle rods will be more than enough to hold the power too. RLZ tuned a car that made 651whp at 24psi w/ the gt35r. had 84 bore and bigger cams. i dont see why you wouldnt make 600 @ 25psi all day long. and what they said about pump gas, dont push it much more than 400whp. it's better on the motor and will save you tire money ha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T »</TD></TR><TR><TD CLASS="quote">7.99 @ 165
Modified by 96 GSR-T at 4:42 PM 7/30/2006</TD></TR></TABLE>
missing 3rd
missing 3rd
