2000 civic si vtec problem?
Old Jul 25, 2006 | 06:25 PM
mtny's Avatar
Default 2000 civic si vtec problem?
Sometimes when I hit vtec it seems to cutout then come back on around 6800 rpms? Wtf is wrong. I searched and all I got was maybe low oil pressure? Maybe solenoid.
engine - b16a2
Modified by mtny at 10:39 PM 7/26/2006
Old Jul 25, 2006 | 07:18 PM
BlueIntegraBoy's Avatar
Default Re: 2000 civic si vtec problem? (mtny)
I'm saying low oil
Old Jul 26, 2006 | 03:43 PM
mtny's Avatar
Default Re: 2000 civic si vtec problem? (BlueIntegraBoy)
I checked it and it was fine.
Old Jul 26, 2006 | 04:04 PM
cambopheonix56's Avatar
Is it old and thin as water? Change it.
Old Jul 26, 2006 | 07:36 PM
mtny's Avatar
Default Re: 2000 civic si vtec problem? (cambopheonix56)
I'm going to change it tomorrow just to be on the safe side, hopefully that will fix it.
Old Jul 26, 2006 | 08:11 PM
hpd_eg2's Avatar
If problem still present after oil change check Solenoid by take it out apart and clean up inside of it. Sometime oil build up inside solenoid. Good Luck.
Old Jul 26, 2006 | 09:36 PM
mtny's Avatar
Default Re: 2000 civic si vtec problem? (hpd_eg2)
I took a look at it (vtec solenoid) earlier (in the dark at around 12 AM). And I couldn't really see how it would be dissambled? Thanks!
Old Jul 26, 2006 | 11:07 PM
**DOHC HaTcH**'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtny &raquo;</TD></TR><TR><TD CLASS="quote">I took a look at it (vtec solenoid) earlier (in the dark at around 12 AM). And I couldn't really see how it would be dissambled? Thanks! </TD></TR></TABLE>
Why dont you try checking it out in the morning.
Maybe when the suns out.. So u can see better
Jus throwing in a lil advice
Old Jul 26, 2006 | 11:52 PM
Frozen E's Avatar
H-T White Ops
Couple of bolts hold the solenoid to the head. Take it off and clean out the screen in there.
BEFORE YOU DO THAT THOUGH, get yourself another solenoid gasket from Honda to replace your old one. Not a good idea to reuse a 6 year old rubber gasket you just pulled off.
Old Jul 27, 2006 | 07:46 AM
mtny's Avatar
Default Re: (IslandSi)
Ok, I'm going to honda today to get a bracket for a swaybar anyway. Thanks!
karkrazy9
Jun 29, 2008 07:35 PM
JSpekBB4
Oct 30, 2007 10:23 PM
h22a1_julien
Aug 27, 2007 01:44 PM
jeremyyeahh
Aug 10, 2007 03:16 PM
crx_kid
Nov 15, 2004 04:47 PM
