99 civic Si cel
Old Jul 25, 2006 | 11:51 AM
Diamond Cutter Lane#1's Avatar
Default 99 civic Si cel
I have a 99 civic si with cel. the code is P0133. I've changed the o2 sensor twice. I even took it to the dealer and they read the same code gave me a new sensor, saying that it is just a lazy sensor or that the headers might be the problem? I have JDM ITR headers, but I don't think that's the problem since I've had them on for 3 years. Can you guys help me with this?
Old Jul 25, 2006 | 12:00 PM
krisjk2's Avatar
Default Re: 99 civic Si cel (Diamond Cutter Lane#1)
stupid question but have to start somewhere. did you reset the CEL?
Old Jul 25, 2006 | 12:49 PM
2000EM1's Avatar
Default Re: 99 civic Si cel (Kris K.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kris K. &raquo;</TD></TR><TR><TD CLASS="quote">stupid question but have to start somewhere. did you reset the CEL? </TD></TR></TABLE>
That was going to be my first question.
My next is did you look at the harness leading from the sensor? Be sure it's not open/grounding itself.
Old Jul 26, 2006 | 09:01 AM
Default Re: 99 civic Si cel (2000EM1)
I've cleared it, but then it would come back within 2-3days. I also check the wires to see if they are open, but they're not.
Old Jul 26, 2006 | 10:01 AM
miahmouse's Avatar
exhaust leak, you're in need of a tuneup, sticky injector...
Old Jul 26, 2006 | 10:35 AM
allaboutdaz's Avatar
Default Re: 99 civic Si cel (miahmouse)
he might be using a test pipe
and that what is etting it up
JDM ITR header needs 2.5 collector so u would need a test pipe or a JDM cat
Old Jul 26, 2006 | 10:43 AM
Default Re: 99 civic Si cel (allaboutdaz)
i'm actually using the stock cat that was fitted for the 2.5 collector. It's welded so their might be a leak. I'm going to have to check that. thanx
alpinegroove
Oct 2, 2014 04:48 AM
junkspeedproject
Feb 5, 2008 01:44 PM
steelrainwarrior
37
Aug 28, 2007 07:40 AM
bluecivic05
Apr 17, 2007 07:28 PM
deca
Jan 20, 2006 04:10 PM
