ECU SECURITY QUESTION?
Old Jul 25, 2006 | 11:22 AM
vtec420kingH22's Avatar
Default ECU SECURITY QUESTION?
Ok, I have a question regarding take the ecu on and off the harness! Every night before I put my car to sleep, I put my autolock on and I disconnect my ecu! Is the ECU in anyway in jeporady of getting damaged?
Old Jul 25, 2006 | 11:31 AM
Perfectionist's Avatar
Default Re: ECU SECURITY QUESTION? (vtec420kingH22)
If the ignition is off, probably not. But repeated removal and reconnection of the the connector may eventually lead to wear problems and subsequent failure. In addition, the ECU will need to relearn idle and other operating parameters, depending on the system type. I would advise against the practice.
Old Jul 25, 2006 | 11:43 AM
so what do you advise I do, to keep my car safe!
Old Jul 25, 2006 | 12:35 PM
civicstar's Avatar
i unplug my ecu, just as long as u turn the ignition on and off a few times before u start the car, if u unplug ur harness the wrong way by pulling on the wires itll lead to tear. what i suggest is hidden kill switches such as a fuel pump cut off, ignition kill or so on. or sleep in the car, haha jk
Old Jul 25, 2006 | 12:39 PM
Default Re: ECU SECURITY QUESTION? (civicstar)
lol..if i could sleep i would..lol
Old Jul 25, 2006 | 02:35 PM
boostedblkef's Avatar
kill switch would be better
Old Jul 26, 2006 | 05:13 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">kill switch would be better </TD></TR></TABLE>
Definitely. Check out the audio/video/security forum for a nice writeup on installing kill switches.
nycpatron
Mar 1, 2010 02:14 PM
patdow1
Apr 21, 2009 04:35 AM
Darren
Jul 18, 2005 05:12 PM
eLeCtRoNSi00
Apr 16, 2004 01:17 AM
