mini-me comp. ratio question
Old Jul 24, 2006 | 05:12 PM
ci_v_ic's Avatar
Default mini-me comp. ratio question
i have a d16z6 head and im about to put it on a d15b7 block so will that raise compression ratio? and if so how much will it raise it by?? im looking at boosting and dont want my comp. ratio to high. thanks in advance for the help.
Old Jul 24, 2006 | 06:05 PM
BauleyCivic's Avatar
Risky Business
Default Re: mini-me comp. ratio question (ci_v_ic)
It will raise it to 10:1. Make sure you run 93 octane gas with it. You will be able to boost it just fine, just make sure it's tuned properly.
Old Jul 24, 2006 | 09:04 PM
ddd4114's Avatar
Default Re: mini-me comp. ratio question (BauleyCivic)
Are there any additional limitations to boosting a b7 block with a mini-me? Obviously it must be tuned correctly the first time, but is the limit still the b7's weak rods? I might run this setup, too.
jrod95cpe
Feb 1, 2009 11:15 AM
Maxcapacity
Nov 15, 2007 02:25 PM
usafa2010
Jul 12, 2005 07:18 PM
BoostedEgHatchFl
May 4, 2005 04:09 PM
onemanlan
May 24, 2004 06:50 PM
