HELP me get this nut off!!!
Old Jul 24, 2006 | 04:22 AM
turbointegrar's Avatar
Default HELP me get this nut off!!!
ok so the 32mm nut on the end on the axel I cant get to budge
i have pounded out the part where it was dented in so it it wouldt turn.
I have broken two wrenches and a breaker bar trying to get this thing off.
please help me i really need to get this apart
Old Jul 24, 2006 | 04:34 AM
Ricey McRicerton's Avatar
Default Re: HELP me get this nut off!!! (turbointegrar)
Step 1. Drive down to a garage.
Step 2. Tell them you'll pay them 10 dollars to break the axle nut loose.
Step 3. Retighten enough to drive home.
Step 4. Remove the nut once you're home.
Old Jul 24, 2006 | 04:48 AM
the car is not drivable
Old Jul 24, 2006 | 05:04 AM
Speed Kills's Avatar
Default Re: HELP me get this nut off!!! (Ricey McRicerton)
Drive to the hardware store and get a Bernz-o-matic propane torch. Heat the nut, then hit it with an impact gun (air actuated, electric ***** **** will not do the job). Borrow one if you've got to, but that's about your best bet.
Old Jul 24, 2006 | 05:16 AM
rmcdaniels's Avatar
Default Re: HELP me get this nut off!!! (Speed Kills)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed Kills &raquo;</TD></TR><TR><TD CLASS="quote">Drive to the hardware store and get a Bernz-o-matic propane torch. Heat the nut, then hit it with an impact gun (air actuated, electric ***** **** will not do the job). Borrow one if you've got to, but that's about your best bet.</TD></TR></TABLE>
That's what finally worked for me, the torch made all the difference.
Old Jul 24, 2006 | 05:25 AM
vbherrera's Avatar
i went to sears, got an electric impact gun.. went at it for 8 minutes straight.. finally broke loose.. went back to sears and got my money back
Old Jul 24, 2006 | 05:37 AM
ive tried the air compressor impact and I have also tried larger breaker bars and pipes on the end on wrenches
I also tried heating it up with a propane torch and nothing
Old Jul 24, 2006 | 05:43 AM
sauceja's Avatar
Default Re: (turbointegrar)
I just had that yesterday where the thing you push to lock into the axle. I couldn't get it pryed out with a screwdriver and had to take my air grinder to weaken the steel so I could get it off with impact. Axle nut is like 2.00 at NAPA and I didn't scuff anything else with grinder.
That is what I did. took about 15 minutes.
Helps to have an air compressor at the house.
Old Jul 24, 2006 | 06:10 AM
instructor74's Avatar
Default Re: (sauceja)
HEAT HEAT HEAT and then the impact gun you might have to tourch the nut off or use a nut cutter
Old Jul 24, 2006 | 06:36 AM
miahmouse's Avatar
Default Re: (instructor74)
pb-blaster + heat + ***** **** cordless electric impact usually works for me, if not then air impact or breaker bar...
There's really not that many tricks to getting axle nuts off.
edit:
other than righty-tighty, lefty-loosey (you'd be suprised, "no **** it won't come off, now lets try loosening it")
stagen
Aug 9, 2007 03:40 AM
the soL that could
Suspension & Brakes
16
Apr 8, 2006 02:03 AM
brx017
31
May 2, 2004 04:01 PM
FUP23
31
Aug 2, 2002 12:20 PM
DragII
Oct 17, 2001 10:42 AM
