Z6 tranny rebuild cost *pic*
Old Jul 23, 2006 | 02:24 PM
eh3 93's Avatar
Default Z6 tranny rebuild cost *pic*
Can anyone give me a ballpark figure on how much it would cost me to rebuild this Z6 tranny. I know it should not have oil on the casing like that. Also, tranny whines in 1st and 2nd on sudden accelerations and also deceleration. Input shaft?
Old Jul 23, 2006 | 02:48 PM
Luserkid's Avatar
Default Re: Z6 tranny rebuild cost *pic* (eh3 93)
Whinning could be caused by many different things. I think it might be the pilot bearing which is a very easy fix. If its a bearing inside the tranny look into spending about 700+
That oil in the case looks like maybe a bad rear main seal or a main seal on its way out.
Old Jul 23, 2006 | 03:41 PM
CRXified's Avatar
ya bad main/rear seal would cause that, i doubt its tranny fluid
Old Jul 23, 2006 | 04:01 PM
eh3 93's Avatar
Default Re: (CRXified)
Ok well my motor is out anyway and is going to be rebuilt so the rear main seal will be replaced along with the release bearing. If that doesnt fix it I'll just replace the tranny. Thanks fellas!
Old Jul 24, 2006 | 08:04 AM
Morning Call's Avatar
my tranny was way worse then that. it took me about 45mins with break cleaners to clean it out. i had some caked on there hardcore. replaced both seals and its fine now
Sr420Det
May 11, 2010 11:09 AM
puertoroc7976
12
Oct 8, 2006 03:00 PM
-tc-
Oct 25, 2005 07:44 AM
Jason C SBB
Jan 25, 2005 10:42 AM
White HB
Aug 2, 2003 06:42 PM
